Oil Pressure
Old Oct 7, 2009 | 09:08 PM
Big D's Ram's Avatar
Big D's Ram
Default Oil Pressure
Well i was wondering what everyone else's oil pressure ran... I have a 2000 Dodge 1500 5.2 with 140xxx and the oil pressure sending unit took a crap on me so i had to replace it so instead of just replacing it with another stock unit i replaced it with an aftermarket oil gage and when i start the truck and its cold it has around 20-30psi and when the truck warms up it goes down to about 10-15 but when i get on the gas it goes up to around 25-30... Is this normal with this many miles but i have never had problems with oil pressure b4... Oh and on another note that oil pressure sending unit is a SOB to replace... I dont know what they were thinking when they put that there... I might have used some words that mite make the neighborhood kids scared...
Old Oct 7, 2009 | 11:13 PM
J415's Avatar
J415
there are actually a couple of threads were people discussed there oil pressure. search it and you'll be surprised...And mine is 40psi when I'm on the gas and a tad over 40psi idling.
Old Oct 8, 2009 | 12:49 AM
roadney's Avatar
roadney
mine is slightly over 40 when I just start it up. after it is warm sits a little under 40 at idle and around 40 on the gas
Old Oct 8, 2009 | 01:08 AM
dodgeram07's Avatar
dodgeram07
you need to run 20-80psi on these motors,,,,,,10-15 sound weak to me
Old Oct 8, 2009 | 02:25 AM
J415's Avatar
J415
80? That sound a bit to high...but what the hell do I know.
Old Oct 8, 2009 | 04:38 AM
pavement_hater's Avatar
pavement_hater
By the book. 30-80 PSI at 2000 rpm's
Old Oct 8, 2009 | 05:10 AM
Sheriff420's Avatar
Sheriff420
a hair under 40 when warm at idle.
about 3 times the width of the needle to the right of 40 when i'm on the gas around 1500-2000 rpms.
Old Oct 8, 2009 | 08:34 AM
Twisted Metal's Avatar
Twisted Metal
From the gauge on the cluster. 30-45 psi. That could be +/- a few psi either way.
Old Oct 8, 2009 | 08:43 AM
halfamil's Avatar
halfamil
35-45 psi here.
Old Oct 8, 2009 | 09:23 AM
Big D's Ram
thanks yall i might just need to do some maintnence like the oil pump and screen etc... Maybe some thicker oil...
