summit headers
Old Oct 9, 2009 | 09:26 PM
xskylinedx's Avatar
xskylinedx
Originally Posted by dodge15004x45.9
But in pa its not worth it in my eyes. Lastrights now has to run 2 cats cause of where they meet now. If you are doing long tubes no better time to do a true dual.
I set mine up with only one cat, why did he have to use two?
Old Oct 9, 2009 | 09:32 PM
dodge15004x45.9's Avatar
dodge15004x45.9
I'm not sure I'm hoping he gets back on here to answer it better than I can.
Old Oct 9, 2009 | 09:37 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
JBA make alot of their headers for other brands. I have JBA shorties and they are excellent in the low-mid range power,
FF
Old Oct 9, 2009 | 09:44 PM
townsley4's Avatar
townsley4
longtube headers require certain mods?
Old Oct 9, 2009 | 09:47 PM
dodge15004x45.9
Yes they are not a bolt and go. You need to redo the y pipe.
Old Oct 9, 2009 | 09:51 PM
95_318SLT's Avatar
95_318SLT
I'm running summit "shorty" headers on my '95 Dakota. They are made by pacesetter, they are a direct fit, and they come with all the hardware you need. I noticed more of a low-mid range power increase than I did upper end. You'll notice an upper end power increase with more intake flow. The finish on them is junk, and is mostly burned off mine, but for the price they are worth it. I wrapped mine to help keep the heat out... which helped drop the heat coming off of them about 200* according to an optical thermometer.
Old Oct 9, 2009 | 09:52 PM
xskylinedx's Avatar
xskylinedx
When you go to longtubes the y-pipe wraps around behind the transfer case instead of the
engine block. This pushes your cat rear ward and also gives less room for the cat and
muffler before the tailpipe arcs upward to clear the rear axle. Basically you end up having
to replace all the piping, cat, muffler, and go with either an O2 simm or supposedly you can
get O2 harness extension. It is highly unadvisable to extend the wiring yourself.
Old Oct 9, 2009 | 10:25 PM
townsley4's Avatar
townsley4
so i would need to extend the 02 sensor if i was to go longtube headers, new cat and pipes? because im thinking about getting new exhaust soon.
wich sounds better, the longtubes or shorties.
Old Oct 9, 2009 | 10:48 PM
TIMIDONE's Avatar
TIMIDONE
anyone out there know the hp difference with putting shorties vs long headers? I am curious to justice which direction I would go.
Stock: 230 hp (right?)
w/ shorties: ?? hp
w/ long: ?? hp
oh and this would be for the 5.9L engine.
Old Oct 10, 2009 | 01:24 AM
dakotas ram's Avatar
dakotas ram
Originally Posted by 95_318SLT
I'm running summit "shorty" headers on my '95 Dakota. They are made by pacesetter, they are a direct fit, and they come with all the hardware you need. I noticed more of a low-mid range power increase than I did upper end. You'll notice an opper end power increase with more intake flow. The finish on them is junk, and is mostly burned off mine, but for the price they are worth it. I wrapped mine to help keep the heat out... which helped drop the heat about 200*
got pics of yours on the engine? id like to see what wrapped headers look like on a magnum
i got my pacesetters used from mohawk....they had a crack that i had to get welded up, but other than that no complaints
