My truck ate a brake rotor
Old Oct 11, 2009 | 10:27 AM
Hammer Down's Avatar
Hammer Down
Default My truck ate a brake rotor
Over the past few days I've noticed a grining vibration and noise when I depress the brake pedel. On closer examination, the inside of the front passenger brake rotor is heavily eroded and scored. The brakes also showed some whisps of smoke after a short trip. Now, I know the obvious needs to be replaced: i.e. rotor and pads, but what needs to be replaced to prevent this from happening again? Do I need a new wheel cylinder or whole new caliper?
Please and thankyou
Old Oct 11, 2009 | 10:36 AM
J415's Avatar
J415
it sounds like your caliper could be sticking. I'd rebuild it just for safe measure.
Old Oct 11, 2009 | 10:37 AM
ksiiqtaboo's Avatar
ksiiqtaboo
if the caliper cannot be compressed you will have to replace it. i had the same problem with my alreo if the caliper compresses then all you need is the pads and rotors
Old Oct 11, 2009 | 01:40 PM
Hammer Down
I went ahead and bought a new caliper and rotor. The metal of the wheel cylinders had chunks missing and the old pad was shredded beyond recognition. I forgot to pick up new pads, but when I take the old caliper back to get my core charge, I can put it towards pads.
Old Oct 11, 2009 | 05:21 PM
8t5gt's Avatar
8t5gt
i have the same problem on my 95 but i can push the piston back in the caliper no problem. i replaced the flexlines when i got the truck because the wheels would lock up, now it just eats brakes quick, think i might just get new calipers i bought it a new set of summit cross drilled rotors( worst mistake ever) because the cheap finish rusted off and now im braking on a completly rusted surface.
Old Oct 11, 2009 | 07:03 PM
Hammer Down
Mission accomplished! New caliper and rotor on the problem wheel and new pads on both front brakes. She stops as smooth silk!...$130 later...not too bad I suppose.
Old Oct 13, 2009 | 06:31 PM
imhotep's Avatar
imhotep
Had my Summit cross drilled and slotted for over a year now with not problems.
Old Oct 14, 2009 | 12:15 AM
dakotas ram's Avatar
dakotas ram
might wanna flush your fluid too, it dont like too much heat
