Cheap but good tuner
Old Oct 13, 2009 | 10:43 AM
offroadjosh's Avatar
offroadjosh
Default Cheap but good tuner
Im looking for a cheap but good tuner for my 1996 5.9L 360 Ram 4x4. I would like a little better fuel mileage if possible.
thanks
Josh
Old Oct 13, 2009 | 11:23 AM
Augiedoggy's Avatar
Augiedoggy
yeah thats an oxymoron......and most of the tuners offer little advantage unless you step up to the more agressive program which requires higher octane gas+ more $.
sta away from the volo ones on ebay...I reasearched them a bit and saw others saw a dyno proven decrease in hp and torque over stock.
and theres only a few options for us 96 owners superchips , mopar pcm and jet performance as far as external tuners I believe.
Old Oct 13, 2009 | 12:07 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Superchips only has them for 98 and up IIRC.
Old Oct 13, 2009 | 01:29 PM
pcfixerpro's Avatar
pcfixerpro
zman covered the superchips. Yeah Augiedoggy, he could go mopar pcm which is a good suggest if he can find one. If you can... go for it. The jet chip is frowned upon on the forum because overtime the computer compensates for the chip, and becomes useless is the consensus on the forum. I don't know for sure since I never tried one, but im sure someone will chime in with that. Hypertech is good to 97 I believe so that is out. The one other solution is... B&G flash which the op can look into.
+1, unless that has changed recently.
Old Oct 13, 2009 | 01:40 PM
Laramie1997's Avatar
Laramie1997
^ Ah, no. SC claims that they can support the late 97 rams. Possible that a tuner for 98 and up will work out of the box, or they will make a one shot tune for it.
https://dodgeforum.com/forum/2nd-gen...er-thread.html
It's what they say at least.
Old Oct 13, 2009 | 01:46 PM
zman17's Avatar
zman17
Besides that, what are you getting for mpg? Next thing you should do before spending any money, is doing a search here for Plenum gasket. Which if blown (which it probably is) will effect the cat and the precat o2 sensor.
Old Oct 13, 2009 | 02:10 PM
pcfixerpro's Avatar
pcfixerpro
I remember that thread, but didn't remember anyone actually going through with it so its just talk for now. Plus the OP is 96, of which neither hypertech or SC offer a tune for.
Old Oct 13, 2009 | 02:26 PM
dodgeram07's Avatar
dodgeram07
sct tuner. I know (96) but didn't the guy with the richer pretty truck get one?... I would look it up. But I dont know his name
He did a reveiw on it a little while back
Old Oct 13, 2009 | 03:50 PM
Augiedoggy's Avatar
Augiedoggy
sct was who I meant not superchips...the 9550 model...and I also read the jet module was crap too..
Old Oct 13, 2009 | 04:31 PM
elementalnature's Avatar
elementalnature
From: Home: Southern KY; Stationed: Southern California
The Review for an SCT Tuner on a stock motor. The review was done on a 96 1500, Richard Petty Series.
+1 Any modification you do is going to require a little more money. The plus side to this is you get a little more MPG.
I would think that Hemifever could probably chock up an SCT tuner for you if the 96s are supported. SCT all the way in my opinion. The only advantage that the Superchips have are that they can calibrate speedos. And I think Hemifever was offering 275 for a stock motor based SCT with 89, 93 octane, and a tow tune I believe. 375 for any modifications such as Cold Air Intake, Exhaust, Headers, Re-gearing, and so on...
