Old 08-04-2015, 07:42 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: General Overview
Print Wikipost
I.O.D. (Ignition Off Drain) Fuse
Old 04-24-2019, 09:36 AM
David Tilley's Avatar
David Tilley
David Tilley is offline
Default Draw
I have a draw at the 50 amp battery fuse under hood. I pull the aod fuse and draw cuts in half and test light flashes. Fuses good.. help!!!
  #42
Old 04-24-2019, 09:58 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,201 Likes on 2,953 Posts
What are you driving? How much of a draw?
  #43
Old 04-24-2019, 11:01 AM
David Tilley
Default Draw
2000 dodge ram 1500 4x4 5.9 ltr.
  #44
Old 04-24-2019, 11:06 AM
David Tilley
Default Draw
Test light lights up pretty bright. Flashes when the aod fuse is pulled. Goes out when the aod fuse and the #14 cluster fuse is pulled.
  #45
Old 04-24-2019, 11:15 AM
HeyYou is offline
What kind of test light???? Flashing is kinda odd..... How much of a draw? Some is normal........ (less than 1 amp.....)
  #46
Old 04-24-2019, 11:25 AM
David Tilley
Default Draw
​​​​​11.3 colts. 6.6 volts when aod fuse is pulled. Then drops to 1.7 volts when the cluster fuse is pulled,no some lights work on this vehicle but a clicking noise when I put the cluster fuse back in. Like a relay clicking behind the dash..
  #47
Old 04-24-2019, 11:30 AM
David Tilley
Default Draw
goes to zero after module goes to sleep..
  #48
Old 04-24-2019, 12:37 PM
HeyYou is offline
There is always going to be some draw, as the PCM needs power to maintain memory. Other sources are various lights that may stay on. (glove box, underhood) I think the derm (for the airbag....) is also always powered, but, would have to check to be sure.
So, when testing, yes, you will see voltage across various circuits, its the AMP draw that matters.... Need a meter to check it though.
  #49
Old 04-24-2019, 02:11 PM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
What draws power when off is radio, PCM, airbag system (so if you get hit while parked airbag goes off, and there are minimum current lose on the wires.
  #50
Old 10-03-2020, 12:25 PM
drlcvette@yahoo.com's Avatar
drlcvette@yahoo.com
drlcvette@yahoo.com is offline
Pulling the IOD fuse: It's not too hard. Pull on the "ears" of the black fuse carrier. It will only come out half way. Then open the clasp on the carrier and remove the fuse. See pics:
Quick Reply: I.O.D. (Ignition Off Drain) Fuse
