Shift from Park to drive "clank clank"?!?
Old Oct 12, 2009 | 09:24 PM
Montey21's Avatar
Montey21
Default Shift from Park to drive "clank clank"?!?
I've got a 95' Dodge 2500 4x4
When I shift from park to drive I hear a metal on metal sound
the best example I know of is like hitting two concrete stakes together
I hold my foot on the break and shift it into reverse and it doees the same thing
once I get rolling there are no other noises
does anyone have any ideas
please!!
Old Oct 12, 2009 | 09:27 PM
Cereal Killer's Avatar
Cereal Killer
Almost definitely your U-joints are worn out. Although mine has a distinctive "clunk" when I shift into reverse most of the time. I'm told it's normal, and all these trucks have it.
I'd check your u-joints for play though before anything else, and if you get new ones make sure you get the kind with grease fittings.
Old Oct 12, 2009 | 11:45 PM
MrRuckuss's Avatar
MrRuckuss
i have that same problem, but i have checked my u-joints and they are all tight i was wondering if it was the transfer case
Old Oct 12, 2009 | 11:47 PM
95_318SLT's Avatar
95_318SLT
Too much backlash in the ring gear will also cause this.
Old Oct 13, 2009 | 12:05 AM
MrRuckuss's Avatar
MrRuckuss
mine only does it in reverse, i should have mentioned that earlier but if it is the ring gear backlash how much of a pain is that to fix? i haven't done a whole lot of that kind of work, i have changed out rearends but that was the whole unit.
Old Oct 13, 2009 | 12:13 AM
Laramie1997's Avatar
Laramie1997
It's a very normal sound from the tranny. Most if not all 2nd gen autos do this. Search around guys, it has been covered.
Old Oct 13, 2009 | 12:27 AM
dodge15004x45.9's Avatar
dodge15004x45.9
Yep mine does it can't miss it. CLUNK she goes and I know she in reverse.
Old Oct 13, 2009 | 07:38 AM
notanexit7's Avatar
notanexit7
yeah I remember the miami guy explaining why it clunks when you put it in reverse. at least I think it was miami.
