blend door plastic interposer fix
Old 10-14-2009, 10:44 AM
mopartimmy's Avatar
mopartimmy
mopartimmy is offline
Default blend door plastic interposer fix
of course mine was broke like everyone elses so i pulled it apart and and brain stormed on a fix.
First i cut slits in it so i could epoxy it back together no pics sorry.
Then i superglued the crack and clampped it back together till it was dry.
After it was dry i filled the slits with epoxy and let that dry.
When that was dry i still thought it would crack so i searched the house for anything that would work and bingo it fits in thin wall PVC just a little tap from a hammer and it slides right in and from the pics you can see what i did. works great so far.
Old 10-14-2009, 01:20 PM
J415's Avatar
J415
J415 is offline
If your talking about the climate control *****, I have a BUNCH of those for sale. Just in case anyones interested.
Old 10-14-2009, 07:27 PM
mopartimmy's Avatar
mopartimmy
no this is the piece that connect the actuator to the door.....this is how i fixed mine
Old 10-16-2009, 12:00 PM
mugsaway's Avatar
mugsaway
mugsaway is offline
I believe my blend door is broke also. Where do you begin? Where is it? How do you get to it? I really need to fix this - it's driving me crazy.....
Old 10-16-2009, 05:59 PM
mopartimmy's Avatar
mopartimmy
check the interposer first they break alot.
it’s on the passenger side right next to the tranny tunnel there will be a black box about the size of a pack of smokes with one visible Phillips in it the other is closer to the firewall (you will need a 90 degree screwdriver that that one) back the one out on the firewall side and remove the one closest to you and you can pull the actuator out of the way then the interposer will connect the actuator to the blend door. the rest is easy.
Old 10-16-2009, 07:39 PM
dodge15004x45.9's Avatar
dodge15004x45.9
dodge15004x45.9 is offline
Are you talking about the door sensor for the inside lights? Mine got pushed in from when I went camping a few weeks ago. (I used a log to push it closed to stop the ding ding ding) I fixed it with a pad of duck tape. Not the best looking buts its a cheap fix.
Old 10-16-2009, 11:00 PM
scottnfwi's Avatar
scottnfwi
scottnfwi is offline
where ecactly is that at
Old 10-17-2009, 08:26 AM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
The OP doesn't give any info about his truck as usual, but I believe it is a later model, that use a small gear driven box to operate the blend door. You 95 is simply cable operated.
Old 10-17-2009, 08:27 AM
zman17's Avatar
zman17
zman17 is offline
Originally Posted by dodge15004x45.9
are you talking about the door sensor for the inside lights? Mine got pushed in from when i went camping a few weeks ago. (i used a log to push it closed to stop the ding ding ding) i fixed it with a pad of duck tape. Not the best looking buts its a cheap fix.
huh??????? Lol Did you actually read the thread? Or just look at the pictures?
Old 10-18-2009, 12:48 PM
004x41500's Avatar
004x41500
004x41500 is offline
the blend door is what makes it go form cold to hot? and how can you test it to find out, whats wrong with it.
Quick Reply: blend door plastic interposer fix
