Blend door?
Old Oct 16, 2009 | 12:59 PM
mugsaway's Avatar
mugsaway
Default Blend door?
Have no idea what is wrong. I think it's the blend door but a mechanic I am not.......
When driving with AC on - it will work but at times it will stop blowing cold air. It in turn blows how air. When this happens I hear a "thunk", like a flap covered a hole - this comes from the glove box area. Also, I cannot adjust the temp....it's either cold or hot.
When driving with AC on - when working but coming to a stop it will start to blow hot air. When this happens I hear a "thunk", like a flap covered a hole - this comes from the glove box area.
When using just the panel or floor setting, I cannot adjust the temp at all. It ALWAYS blows hot air.
Can this be the blend door? Can I be lucky enough to just replace the control panel? If the blend door, how much of a pita will this be? Can I do this myself? Where is the blend door located and how to I get to it?
Thanks
Old Oct 16, 2009 | 04:29 PM
Miami_Son's Avatar
Miami_Son
Do a search for "wild or crazy vents" as this has been covered in detail already. The blend door may not be the problem.
You didn't need to start a new thread on this after you already posted to the "blend door fix" thread.
