single plane intake manifold
Old Oct 15, 2009 | 04:42 PM
TIMIDONE's Avatar
TIMIDONE
Exclamation single plane intake manifold
what advantages does this give us? is it an overkill unless we have many other mods? I am just curious cause I saw a posting for one for sale...this would need a match tb right?
ANY info would be great!
Old Oct 15, 2009 | 05:08 PM
dodgeram07's Avatar
dodgeram07
better mpgs and more power,,, its like the dream drug and no one the tb just bore out your junk yard on or get the 52mm or run stock
Hahns5.2's Avatar
Hahns5.2
First, you get rid of the belly pan and it's gasket. Second, it carries the torque/power higher into the RPM range along with more power, instead of falling in it's face at 4500, mine still pulls hard to 5500. Without supporting mods, it does reduce low end torque a little, with the mods I have (mainly after I added the Mopar PCM) I got that low end torque back and easily have more than stock.
Old Oct 15, 2009 | 05:18 PM
dodgeram07's Avatar
dodgeram07
oh right,TIMIDONE you talkin M1 or the air gap?
Old Oct 15, 2009 | 05:35 PM
TIMIDONE's Avatar
TIMIDONE
umm I have limited mechanical knowledge but neither...pretty sure it is just referred to as a single intake manifold...I think.
I was just curious because I know where I can pick up a used one for $300 I believe.
Old Oct 15, 2009 | 06:37 PM
Twisted Metal's Avatar
Twisted Metal
Tim, check it carefully before purchasing. Both the M1 and Air Gap are made in both carb and FI versions. The FI one costing alot more (of course). But the are not interchangeble. A carb version will not have the bosses for the injectors. It easy to tell, an FI version wll have 4 extra holes per side toward the middle of the intake for the injectors. Also some will have mounting bolt holes for both Magnum, and older LA style heads. Meaning, you will have to plug the unsed holes as well. If it all checks out, and its in good condition, 300 is a real good deal.
Old Oct 15, 2009 | 06:50 PM
TIMIDONE's Avatar
TIMIDONE
hey now I get it, thanks!
Old Oct 15, 2009 | 09:10 PM
dodgeram07's Avatar
dodgeram07
but Hahns5.2 is right on the m1 and a little bottom end lose,,,, and air gap is good all the way around
just wanted to put that out there
Old Oct 15, 2009 | 10:01 PM
lastrights's Avatar
lastrights
airgap a way better buy i wouldnt waste money on m1 less if your doing alot of motor work
Old Oct 15, 2009 | 11:43 PM
estech2's Avatar
estech2
I have an M1 (original casting, not the new junk) on my 360 and it is smokin once the truck gets moving, bottom end is lacking but I get 18 to 20 HWY if I stay out of it, I can be rollin at 65 and floor it and It will break your neck. Do it dude its only money!!!
