Power Loss?
Old Oct 18, 2009 | 02:28 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by Pyromanaron
Check your air filter. I forgot to clean mine (its a K&N) for a while and it did the same thing.
Next time I lose power and have no lights, I'll be sure to check the air cleaner! LOL
Old Oct 18, 2009 | 03:34 PM
Jvello15's Avatar
Jvello15
It happened again today when I was leaving work and all power is lost and then I pop the hood.. and next thing I know the light underneath the hood comes back on and power is restored.. weird. I'll have to check your guys suggestions starting with the battery/alternator testing.
Old Oct 18, 2009 | 03:37 PM
Sheriff420's Avatar
Sheriff420
that's the first place i'd check. also, don't we have an alternator relay and fuse? it wouldn't hurt to pull them out and re-seat them, they might have corrosion on them that is creating a poor contact.
Old Oct 18, 2009 | 03:47 PM
zman17's Avatar
zman17
All the ground wires need to be checked first. If the battery or alternator was bad it would just be dead and /or barely start. Not just come back full power. Seems like popping the hood is enough of a jolt to help the bad connection. Check the ground wires running along side the manifold that connect to the PS pump bracket.
Old Oct 18, 2009 | 03:52 PM
Jvello15's Avatar
Jvello15
Alright will do. As far as the connection to the battery itself, that was the first thing I check when the power completely cut off on my yesterday for the first time and there are no signs of corrosion and the connections were tight.
Old Oct 18, 2009 | 04:17 PM
zman17's Avatar
zman17
You still took them off and cleaned them right? You don't have to see corrosion for there to be a bad contact. And make sure the posts themselves don't move or twist.
Old Oct 19, 2009 | 07:30 PM
Jvello15's Avatar
Jvello15
No I didn't as I was at work when I checked them but I will be sure to do that wednesday as it is my day off.
