Dropping valve body
Old Nov 15, 2009 | 11:12 PM
  #51
xray99's Avatar
xray99
Its still throwing the "PO748 Pres cntrl solA circuit electrical" code that it was throwing before, and which the replaced harness was supposed to have fixed.
Wonder if it could be the pressure solenoid itself ?
Old Nov 16, 2009 | 02:04 AM
  #52
J415's Avatar
J415
Why didn't you replace the entire assembly when you were down there? did you reset the PCM?
Old Nov 16, 2009 | 02:33 AM
  #53
xray99's Avatar
xray99
What entire assembly ?
The sensors ?
I replaced those about half a year ago, I was told by what I thought was a professional that the harness was the problem, I am not the type to go throwing parts at a problem just hoping it will work.
That said, I think my next course of action will be to replace the damn sensor, and hope that it works.
I kept all my ATF jugs just for that reason, so I don't have to blow another $50 on fluid - Luckily for me, I got a drain
plug in my pan.
If that don't work, a new PCM.
If that don't work, I'm screwed.
I had the batt unhooked for about an hour, that should have reset the PCM.
Old Nov 16, 2009 | 03:08 AM
  #54
J415's Avatar
J415
...I am not the type to go throwing parts at a problem just hoping it will work.
Well, call me crazy but isn't that exactly what your doing?! What ever works man.
Old Nov 16, 2009 | 04:45 AM
  #55
xray99's Avatar
xray99
Twas meant to be intentionally ironic, I thought you'd get it.
I'm no trans specialist, but a "PO748 Pres cntrl solA circuit electrical" code can't be too many things.
I'm confidant of the wiring, to that leaves the sensor, or a bad ground - Someone please correct me if I'm wrong, not a whole **** load of info about this code out there.
Old Nov 16, 2009 | 09:12 AM
  #56
sawtooth's Avatar
sawtooth
There's quiet a bit of info about troubleshooting code P0748 here:
http://dacooley.com/RamStuff/1997/au...0diagnosis.pdf
Old Nov 16, 2009 | 10:09 AM
  #57
zman17's Avatar
zman17
Retired Moderator - RIP
What makes you think a used PCM would help ?
The voltage regulator went bad to begin with, and who knows what could have happened to it when it was rigged to bypass it and shorted ,or whatever happened there when the guy f'd it up.
Old Nov 16, 2009 | 02:18 PM
  #58
xray99's Avatar
xray99
Thanks for the link saw, pdf's crash my system for some reason, I'll have a look when I get that fixed.
zman, charging is not an issue now, truck shuddering then dying when put into gear is the problem.
That may be PCM related, I don't have anything concrete to suggest that it is, or even could be.
If the new solenoid doesn't work I'll try it, a guy on ebay has them for $180 shipped, and programmed by VIN. He offers a 14 day return, only losing the shipping charge so that sounds like a chance worth taking.
Old Nov 16, 2009 | 02:34 PM
  #59
sawtooth's Avatar
sawtooth
Text version of 1997 AUTOMATIC TRANSMISSIONS Diagnosos Chrysler 42RE, 44RE, 46RE & 47RE - Electronic Controls:
http://74.125.95.132/search?q=cache:...nk&cd=10&gl=us
Old Nov 16, 2009 | 03:10 PM
  #60
xray99's Avatar
xray99
Wow, quite comprehensive.
Out of my league to perform most of those checks, certainly does appear it could well be PCM related though.
