New front bumper time.
Old Oct 21, 2009 | 07:45 PM
Dr Donut's Avatar
Dr Donut
the bumper on that dakota is bad ***, I want one!
Old Oct 21, 2009 | 08:02 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Originally Posted by dodgeram07
https://dodgeforum.com/forum/2nd-gen...nt-bumper.html
i like this,,,, pm him and see if if will put up more pic
Simple my friend simple.
Old Oct 21, 2009 | 08:03 PM
dodge15004x45.9
Originally Posted by Aubrey
That doesn't change the spring rate to compensate for the couple hundred more pounds you're going to hang off the front of your truck.
That last one is fugly. Fuuuuuuuuuugly
Yea I would do a few things diff from what he did. I would make it taller and put a plate on top of it.
Old Oct 22, 2009 | 01:05 AM
dodgetrucker75's Avatar
dodgetrucker75
i know you probably dont want to spend a lot of time and money on the bumper, but the one i built for my dakota, i only had a weekend into it and about $150...
https://dodgeforum.com/forum/3rd-gen...s-of-pics.html
Old Oct 22, 2009 | 01:11 AM
dodge15004x45.9
I would rather spend the time and have something that can be but thew its paces than something that I go to use and get stuck and it RAPES my front end. Can you explain the reenforcing the front end a bit more?
Old Oct 22, 2009 | 03:09 AM
dodgetrucker75
well, after i destroyed my front end, (just had the elongated holes, for adjustment), (and my brackets are mount to the inside of the frame rails), i plated the out side two holes of the frame with 1/4in. steel, then extended my bumper mounts to the cross member, and ran a piece of steel across the cross member, with a bolt through either side,( close to each frame rail) and added a bolt through the front body mount & through the bumper brackets as well, all are direct fit holes, so if the bumper moves, it has to take the frame with it. if needed, i will try to get some pics up
Old Oct 22, 2009 | 03:27 AM
dodge15004x45.9
I would really like to see some pics! Thanks. So let me try to understand what you are saying here. You beefed up where the bumper bolts to the frame of the bumper and the frame it self? And looking threw yr bumper you used 3/16 for the hole bumper!! I'm not sure if I want to/need to and a winch or not. I'm sure it would be killer but if it gets stole for my ram there will be blood!
Old Oct 22, 2009 | 10:22 AM
Aubrey's Avatar
Aubrey
If you're go so far to make a beefy bumper for the front, just go the extra step to put a winch in it if you want to later on. That way it is already done. I think eventually you may get to the point where you'll want a winch.
Having a winch is like having Viagra, you jut go farther and deeper in the bush.
Old Oct 22, 2009 | 02:37 PM
dodge15004x45.9
Do you have custom bumpers?
Old Oct 22, 2009 | 03:08 PM
big.red.ram's Avatar
big.red.ram
ya check out his albums
