New front bumper time.
Old Oct 23, 2009 | 04:32 PM
  #31
dodgetrucker75's Avatar
dodgetrucker75
i will try to get pics up tonight of the frame, as for your coils... http://cgi.ebay.com/ebaymotors/2-2-5...item439a6c42a1
Old Oct 23, 2009 | 07:38 PM
  #32
dodge15004x45.9's Avatar
dodge15004x45.9
Originally Posted by Cereal Killer
You should have a hitch receiver welded into your bumper so you can get a receiver winches, that way you can atatch it to the front or rear bumper as needed, plus if you ever need pulled out or need to pull someone out from behind you can just put a hitch in your front bumper. Even better than tow hooks.
Yep that what I want to do winch wise. But I really need to see pics of how you guys when about doing the frame work. I'm thinking of doing 1/4 on the front and 1/8 on the sides to try to save some weight. Right now I'm on the fances for the new coils. Its a lot more money that I don't really want to spend.
Old Oct 23, 2009 | 08:00 PM
  #33
Hahns5.2's Avatar
Hahns5.2
1/4" works good for mounts/brackets and the center of the bumper, 1/8 when triangulated it pretty damn strong for the outside of the bumper. 3/16" is a good compromise. C channel also works but it's kind of a pain to work with. Just don't go absolutly huge, think about approach angles and such.
Bumpers I've built
Shackle tabs inside the ranger bumper.
My B2.
Old Oct 23, 2009 | 08:16 PM
  #34
dodge15004x45.9
Yea I don't want it down to the ground. Like I said he is a welder by trade. So he knows how to do it and do it right. Plus he can get the c channel for free. Unless there is another type of metal I should look at besides plate steel. Mind you this all will be cut with grinder/saw sawzall no plazma at his house yet. He does want to get one put no money for one.
Old Oct 23, 2009 | 09:26 PM
  #35
Hahns5.2's Avatar
Hahns5.2
C-channel and plate is what is normally used, square tubing works too depending on your needs.
Grinders take forever for making bumpers and all the dust is itchy as hell but it's cheap. We've got a torch but no plasma, most cuts we do with grinders.
Old Oct 23, 2009 | 09:40 PM
  #36
dodge15004x45.9
Yea so I'm fine doing channel and diamond plate. 1/4 on the front and 1/8 on the sides and trailer hitch.
Old Oct 23, 2009 | 10:25 PM
  #37
dodgetrucker75
heres the pics
Old Oct 23, 2009 | 10:31 PM
  #38
dodge15004x45.9
Did you just get ride of the stock brackets out right and make your own? Are they 1/4 bolts or 1/2 bolts.
Old Oct 23, 2009 | 10:38 PM
  #39
dodgetrucker75
oh ya, no stock brackets... on this 98 the brackets are 1/2'' and the rest of the bumper is 1/4'' and 3/16'' and all 1/2'' geade 8 bolts
Old Oct 23, 2009 | 10:41 PM
  #40
dodge15004x45.9
What grade 8 mean? Super strong I take it. Can they be found at lowes or home depto?
