Wish Me Luck...Plenum Fix
no im not doing the kegger mod (im getting a whole new intake when i rebuild it in the spring.) can i reuse the hughes plate to new intake?
and its for my egr, so what if i dont hook it back up, will it screw things up? (i striped the part that goes into manifold, so i tool the bolts out from exhust so pipe is still on manifold) an the bolt i took out snapped.
So do necessarily need this pipe coneected? i dont have emissions and i just got a sticker 2 months ago
IDK, I have a 99 and dont have to deal with emissions crap.
What kind of intake are you getting?
havent started researching yet since its about 6 months until i re-do it.
im getting my heads ported and polished. new head gaskets. new manifold, header back exhaust, new camshaft/bearings, rockers, push rods. and hopefully pistons.
ill have about $2500 to play with im hoping, if i dont have to keep dumping money in now.
unless you use another kegger you want need the plenum plate.
if you dont hook it back up make sure the intake gets plugged and the same with the exhaust.
2500 ??? how do you guys keep doing that much work for that little money???
i havent really researched yet. thats what i have to play with, and those are what i want to do.
i hope its not more than that....
i know for a whole gasket kit its 93.00
and the exhaust i want (dual flowmaster 44 with dual 3 in pipe) is $520
the Cat i want is the high flow from summit
and the headers i can get both for 185
and to get my heads ported and polished 600
so thats about 1600 right there. hopfully the intake, push rods, camshaft, bearings, rockers and pistons arent more than 900
plus im gunna need money to get head gaskets done
i have a center divider in my intake (which is getting cut off when i do the plenum) and i don't have an egr tube.
