Wet floor
Old Oct 23, 2009 | 06:49 PM
Rick A's Avatar
Rick A
Default Wet floor
Hello, everyone; I'm hoping someone here has seen this problem and can offer some advice. I have water lying on both sides of the cab floor of a '97 2500. The AC drain isn't plugged (and I wouldn't think would leak onto the driver's side anyway). It's been suggested that the cowl drains may be plugged, but I've looked underneath and can't find them on either side. Can anyone advise where to look? The owner thinks the leaking started when he had the truck painted and the weatherstripping was removed and replaced. I can't see anything wrong with it and kind of doubt that's the cause of the leak, but I've been wrong before (often, in fact). Any advice will be appreciated.
Rick A
Old Oct 23, 2009 | 07:08 PM
97black_ram's Avatar
97black_ram
It could be the third brake light on the cab needs pulled off and silicone added to create a better seal. There know to create the problem your explaining.
Is your coolant low in the overflow tank?
Old Oct 23, 2009 | 07:33 PM
dodgeram07's Avatar
dodgeram07
also check this area,, my brake light and this\/ were leakin
Old Oct 23, 2009 | 08:13 PM
95RAM360's Avatar
95RAM360
+1 on the third brake light, but you would notice it before it hit the floor.
(had leak there on mine)
Old Oct 23, 2009 | 08:19 PM
Augiedoggy's Avatar
Augiedoggy
I have it on the passengers side and havent rules out my heater core leaking yet but also think is may be weatherstripping....if it started after you had your weatherstripping done I would suggest showering your truck with a hose (or have someone do it while sitting inside looking for leaks...carwash may or may not work too.
Old Nov 7, 2009 | 12:08 AM
Rick A's Avatar
Rick A
Default Thank you
I'd like to thank the guys who replied to my question. It seems that the problem is, indeed, the brake light. I sealed around it and the floor is starting to dry out (that takes awhile; we get about 150" of rain per year here in Hilo, HI).
Rick A
Old Nov 7, 2009 | 06:20 AM
95RAM360's Avatar
95RAM360
look on the roof against the back window. is all the fabric wet up there?
Old Nov 7, 2009 | 08:04 AM
moldboard's Avatar
moldboard
Default 2000 dodge 1500
smell antifreeze inside of cab but no leaks under dash seems carpet is wet by drivers door also coolant level seems to stay up pretty well to norm
Old Nov 7, 2009 | 08:49 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the second generation Ram section,
FF
Old Nov 7, 2009 | 09:05 AM
moparama's Avatar
moparama
coolant stays up pretty well or you add just a little at a time?
