What's the best lift for my 01 ram 1500
I have a 2001 second generation ram 1500 club cab 4x4.
What is the best suspension lift kit for it. I want 6"+. Ill drive mostly on the road but go mudding on the weekends.
Who has the best lift for the money that includes everything that i need? Shocks, brake line extensions, etc...
Thanks
Thanks
the x series has adjustable control arms which i wish i would have got cause you can do a level kit and add a leaf and get 7in out of that lift. shock boots are $3.10ea. it comes with everything, sway bar drop bracket, coils, shocks (which i upgraded), blocks, u bolts, pitman arm, control arms, bushings..., it didn't come with break line extensions but it did suggest them. what i did was unbolt the bracket from the frame and i haven't had a problem yet and you can see how mine is flexed in my sig pic with the tire off the ground.
Best "kit" out there for our trucks is the skyjacker 7" long arm
http://www.truckaddons.com/Catalog/s...-dodge-2-8.htm
or if you really wanna do it up the 7" long arm with coil overs, but it's pricey.
http://www.truckaddons.com/Catalog/s...-dodge-2-9.htm
Anything bigger than that you're going to have to piece together yourself.
Holy ****, that's not that much more than the 7" coil over skyjacker lift...
That'd be good for 44 inch tires... whew...
