Rims...of course!
Old 10-27-2009, 07:44 PM
Cereal Killer's Avatar
Cereal Killer
Cereal Killer is offline
Originally Posted by gipperkid
I would go with a 16x10 and 305/70/16. I think you would be stretching that 285 to far on a 16x10.
And you'd be correct. While it's totally possible it's not really a good idea. should you for any reason ever have to lower the air pressure (like in snow, ice, or mud) the tire has a total risk of coming off the bead with that wide of a wheel.
  #32
Old 10-27-2009, 07:52 PM
Augiedoggy's Avatar
Augiedoggy
Augiedoggy is offline
I thought it was the second number (70 or 75 in this case) that was the tire width and the 285 was the height...but googling proved I had it all wrong.Guess I'm just to used to the size broken down in inches....
  #33
Old 10-27-2009, 11:04 PM
TIMIDONE's Avatar
TIMIDONE
TIMIDONE is offline
backspacing I totally get now...I think...the lower the backspacing the more it will stick out. So 3.5 backspacing will stick out more than 5 backspacing.
What I am still a little confused is the offset...explain someone. Stock rims are about 13mm...
I found some rims I am interested in but they don't list backspacing and only offset of 0...will it stick out? Click the link below for the rim...anyone got experience with it or the brand?
http://www.discounttire.com/dtcs/fin...&rw=&rc=ORPINT
  #34
Old 10-28-2009, 12:07 AM
Cereal Killer
Offset is the distance between wheel center line and the wheel mounting surface. negative is where wheel mounting surface is inside of center line. positive is outside center line.
Backspacing is the distance from the back of the wheel mounting surface to the outer most part of the inside rim. So yes, the larger the number back spacing the closer your wheel is to the control arm, the lower the number the more your wheels will stick out past the fenders. So for example wheels with 3.5" back spacing will stick out further away from the truck vs. wheels with 5" back spacing, which is stock.
  #35
Old 10-28-2009, 12:08 AM
TIMIDONE's Avatar
TIMIDONE
TIMIDONE is offline
so positive pushes it out...right? I'm a little slow right now :P
  #36
Old 10-28-2009, 12:12 AM
dodge15004x45.9's Avatar
dodge15004x45.9
dodge15004x45.9 is offline
The lower the number the more mud is on the side of your truck.
  #37
Old 10-28-2009, 12:18 AM
Cereal Killer
No, negative would actually push it out because negative would have your hub closer to the backside of the wheel (closest to the frame) deep dish style.
Positive offset would have have the hub closest to the outside of the wheel (the side of the tires you can see without being under the truck)
  #38
Old 10-28-2009, 12:29 AM
TIMIDONE's Avatar
TIMIDONE
TIMIDONE is offline
darn that means only 1/2" stick out more...that is nothing! I wish I knew the dang backspacing to those rims I posted above!
  #39
Old 10-28-2009, 12:34 AM
Cereal Killer
Couldn't tell you. The link takes you to some perifilate bull**** or something.
  #40
Old 10-28-2009, 12:37 AM
dodge15004x45.9
Yea it does.
