Lug Conversion
Old Oct 26, 2009 | 11:54 PM
RedRam99's Avatar
RedRam99
Default Lug Conversion
alot of the wheels i like only come 6 and 8 lug
Is there a way 2 make them fit my 5 lug ram 1500?
..like a lug conversion? or ram 2500 hubs?
Old Oct 27, 2009 | 01:47 AM
JackJ's Avatar
JackJ
You can buy adapters form some places. I know they make em for ricers any way. But using those it will be just like wheel spacers and those cause un-needed wear and tear on axle parts. Google lug conversion for you set up, there is always someone that has done it.
Old Oct 27, 2009 | 01:51 AM
elementalnature's Avatar
elementalnature
From: Home: Southern KY; Stationed: Southern California
http://adaptitusa.com/
Make sure you buy 5 on 5.5 to whatever conversion you want and always torque your nuts to the correct specs.
Old Oct 27, 2009 | 09:52 PM
RedRam99's Avatar
RedRam99
cool thanks guys
Old Oct 28, 2009 | 12:46 AM
dakotas ram's Avatar
dakotas ram
if you dont want adapters, for the rear, you could just swap in a junkyard axle, but not sure if the front is similar enuff to swap easy
Old Oct 28, 2009 | 12:55 AM
dodgeram07's Avatar
dodgeram07
that makes me wonder if 2500 brake rotor/hub will fix on a 1500 spinlde,,,, maybe 1500 and 2500 spindles make the same?.. if so the front would be cake walk
Old Oct 28, 2009 | 03:03 AM
JackJ's Avatar
JackJ
iirc The rear axel for the 2500 and 1500 are different, they would then use different shafts and they wouyld have a different spline count.
Old Oct 28, 2009 | 03:15 AM
dakotas ram
i was talkin about the whole rearend, if the shaft is diff, grab it too, of course he would also need the hangers and springs
