engine surging problem
Old Nov 1, 2009 | 01:13 AM
wjxavier's Avatar
wjxavier
Default engine surging problem
i've been having a few issues lately with my engine surging under certain conditions. every time i go up a hill when i'm in overdrive, the engine will start to surge. everytime i gas it, when im in overdrive, going up a hill, it surges ALOT. and sometimes it will surge when i'm coasting downhill.
just curious if anyone has any ideas as to what this could be. any info is appreciated. thanks!
Old Nov 1, 2009 | 03:53 AM
Sheriff420's Avatar
Sheriff420
the tps is normally what causes surging under load.
surging with your foot off the gas can normally be blamed on the IAC.
the brake switch can be to blame.
the wires on the bottom of the valve body on the transmission could have rubbed through the insulation.
what fixed my surging after a new tps, iac and camshaft position sensor was doing the spark plug wire re-route.
Old Nov 1, 2009 | 11:15 AM
wjxavier's Avatar
wjxavier
i replaced the tps and iac last year at around this time i think. i was thinking about doing the sparkplug wire reroute, but we'll just have to see. i did however change my tranny fluid earlier this year. but i don't remember there being any wires that were rubbing or touching anything.
Old Nov 1, 2009 | 11:26 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Either one of those sensors could be bad again, especially if you got cheap ones from AZ or wherever.
Old Nov 1, 2009 | 03:04 PM
Sheriff420's Avatar
Sheriff420
there is a bundle of wires on the bottom of the valve body that you can see when you drop the pan. one guy had them rub through and posted about them making his truck surge for a while.
the re-route and new spark plug wires finally got rid of it for me.
i forgot to mention new wires earlier, the #7 wire had a crack in it right next to the boot.
Old Nov 1, 2009 | 04:19 PM
zman17's Avatar
zman17
Here is the post about the tranny harness, https://dodgeforum.com/forum/2nd-gen...ise-speed.html
And here is the TSB for the spark plug wire reroute, http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
Of course I still suspect the TPS 1st and/or IAC.
Old Nov 1, 2009 | 09:38 PM
wjxavier's Avatar
wjxavier
i'll look into those...i still have my old tps that worked perfectly fine(it was from a part changing expedition to find out why my truck was stalling last year) haha. thanks for the help guys
Old Nov 1, 2009 | 09:48 PM
J415's Avatar
J415
by any chance, did you check it with a multimeter?
Old Nov 2, 2009 | 12:46 PM
wjxavier's Avatar
wjxavier
no, i have not checked it with a multimeter yet, but i haven't really had the time to do much of anything with it. i'll probably work on it early next morning when i get out of work. thanks for the advice!
Old Nov 2, 2009 | 01:49 PM
J415's Avatar
J415
do you have a haynes manuel to know what the specs are?
