AHHH!! Rear shackle snapped...
Old Nov 4, 2009 | 04:40 PM
  #21
zman17's Avatar
zman17
Retired Moderator - RIP
Try loosening the bolts and let the spring/shackle settle at the right height/angle. Look for a broken leaf too. Or the pack may have bent after it broke and you drove a little with it.
Oh and btw, my Mother lives in Londonderry.
Old Nov 4, 2009 | 04:43 PM
  #22
JackJ's Avatar
JackJ
Originally Posted by zman17
Well it's one reason anyway! Tires exploding and trucks flipping is the main reason.
And randomly catching fire.
Old Nov 4, 2009 | 04:56 PM
  #23
95RAM360's Avatar
95RAM360
it snapped as i turned into the dealership, and i had to drive 14 miles back home like that...the leafsd rent snapped, i did check for that. ill try loosing the bolts and see if that helps
Old Nov 4, 2009 | 05:18 PM
  #24
360mag45's Avatar
360mag45
don't want to make you feel bad but be glad you got that dicount because i was just looking for new shackles for my truck cause mine are geting rusty here is a set from summit for only $63.00 http://www.summitracing.com/parts/BE...uck+Cab%7cClub
Old Nov 4, 2009 | 05:31 PM
  #25
zman17's Avatar
zman17
I would have suggested going here if he posted the problem before buying new stuff. Since they are located right off exit 5 in Londonderry. If you need new springs give them a call. I paid around $70 for a shackle w/bushing,2 new bolts/nuts and a bushing for the spring.http://www.donovancompany.com/
Old Nov 4, 2009 | 05:46 PM
  #26
AlabamaRam95's Avatar
AlabamaRam95
thats not a bad price.
Old Nov 4, 2009 | 06:05 PM
  #27
360mag45's Avatar
360mag45
since mine are going bad and gonna need to be replaced would that be all i need to replace them http://www.summitracing.com/parts/BEL-6404/ or well i need to get other stuff?
Old Nov 4, 2009 | 06:18 PM
  #28
95RAM360's Avatar
95RAM360
you need the bolts. and the reason i got it from the dealer, s because it literally snapped turning in as i said. and with a problem like that i dont want to sit on it, so i grabbed the part, since eveything was in stock
Old Nov 4, 2009 | 06:28 PM
  #29
360mag45's Avatar
360mag45
alright cool i just was reading the discription and it said about haveing hardware so i thinck they come with thanx for the feed back did you figure out the leveling problem?
Old Nov 4, 2009 | 06:30 PM
  #30
95RAM360's Avatar
95RAM360
i think the shock blew out. its at 1 1/2 inch difference now with lossening the bolts and letting it level, but i hope when i change the other shackle it might level it. I just replaced the suspension, but with the rear, i went with the $21 Monroes, so i think when it snapped all the prssure blew out the shock. Because when i was jumping on the bumper to test it, it bounced a few times after i stopped and usually if it bounces 4-5 times more after you stop bouncing it, the shock is most likely gone.
i havent checked yet bu is there any good trailing i can do in Londonderry Zman?
