Heat controller question!
Old Nov 4, 2009 | 09:30 PM
ice01's Avatar
ice01
Question Heat controller question!
Ok. My heat control in my truck is either just cold or hot, nothing in between. I can turn it slowly from either hot or cold and it does not change one bit until I get a little over half way, then it is just hot or cold. EVery other vehicle I owned gets cooler and hotter with each increment I turn the temp ****. Why is this on not working! Someone said on here before that they thought it might be the control pad behind the ****. Anybody got an answer!!
Old Nov 4, 2009 | 10:15 PM
PurplDodge's Avatar
PurplDodge
Sounds like a problem with the blend door.
Old Nov 4, 2009 | 11:05 PM
halfamil's Avatar
halfamil
Mines been kinda like that since day one.
Old Nov 5, 2009 | 02:28 AM
dodgeboy01's Avatar
dodgeboy01
well what about my problem it blows only hot... how do i get to the blend door? i have a 2001 dodge ram 4x4 2500
Old Nov 5, 2009 | 06:44 AM
95RAM360's Avatar
95RAM360
the dash's are real easy to take apart in these trucks. take out the ash trey/drink holder (if those how yours is set up) and then the bezle pops off, and you'll be able to get to mostly everything.
but just so you know they arent supposed to be like that...mine gets cooler warmer whenever i move it. but i do have a new radiator, water pump, fan clutch, and thermostat
