360 power ????
Old Nov 5, 2009 | 03:23 PM
NAILS's Avatar
NAILS
Default 360 power ????
when i bought my 1998 4x4 quadcab slt larime v8 magnum, i thought it had the 318 in it. but i quickley realized it is a 360. So my question is i feel like i should have alot more power than i do. shouldent i be able stand on it at a stop light and just smoke the tires. i am getting about 9 miles 2 the gallon driveing in town, so i changed my spark plugs and air filter. it didnt help either issue at all. it has 170 thousand miles and my tite size is 75r16, anyone have any advice or tips????
Old Nov 5, 2009 | 03:42 PM
Miami_Son's Avatar
Miami_Son
I advise you look around the forum and try doing some searches. There's lots of threads on getting more power out of these trucks, but the reality is that they are not screamers (well, my V10 is, but the V8s...not so much). There are a number of issues inherent to the V8s that can cause poor mileage and bad performance. Try a search on plenum gasket for a start.
Old Nov 5, 2009 | 03:43 PM
95RAM360's Avatar
95RAM360
plenum gasket is blown. with 170K definatly
Take the air breather off. and look down into the throttle body. if you see oil, its blown.
i just replaced mine. quite easy to do might i add. but if you do do it, ge the hughes reienforcment kit. it makes it so you dont have to replace the plenum again. if you repace it with a normal gaske, it will last maybe 50K
i was getting 9-10 miles city about 13 highway. and this is no joke. i changed the plenum, im now averaging 13-14 city and about 18 highway, and the power i have now is awesome
Old Nov 5, 2009 | 04:13 PM
360mag45's Avatar
360mag45
sorry to say but if i rember right these 360s only have like 250hp at the wheel so theres not a alot regear it with 4.10s new intake headers roller rockers and you should be just fine then but just search around on geting more power out of theses motors
Old Nov 5, 2009 | 04:37 PM
95RAM360's Avatar
95RAM360
+1 i love my 4.10s
Old Nov 5, 2009 | 04:59 PM
2k1AmberR/T's Avatar
2k1AmberR/T
It's 250 at the crank, not the tires. Roughly 200ish at the tires. Not much at all, especially in a big truck like that.
Old Nov 5, 2009 | 05:13 PM
MAJohns's Avatar
MAJohns
question on replacing the plenum gasket what is the average time frame on the job?
Old Nov 5, 2009 | 05:46 PM
360mag45's Avatar
360mag45
ooo thats right
still 250 is bad enoff but 200 is just sad
Old Nov 5, 2009 | 05:54 PM
dodgeram07's Avatar
dodgeram07
also check the cat
Old Nov 5, 2009 | 07:03 PM
95RAM360's Avatar
95RAM360
took me a total of 18 hours. 6-7 hours of cleaning. then at the end, about 2 hours of BS'ing cuz the fuel injector o-rings leaked, and i routed the dist. cap wires wrong.
also i changed the thrmostat. Dis.cap, valve coer gaskets as well and that time is included in the 18 hours. also the half hour to bleed the cooling system
but all in all it was a really simple job. Only special tool i needed was a fuel line disconnect
