Cold Start Rough Idle
I just recently put Fuel Injector Cleaner from STP into my gas tank, and it idles like a champ. Maybe that was an exaggeration, but it does idle much much better. I can still tell when it starts to idle a little rough, but it works itself out now, and does not start to shake the whole cab and sound like it is going to stall.
Has this been fixed ? What did it take to fix it?
Has anybody found the root cause to this problem. I'm having the same symptoms and have tried just about everything trying to fix it. New IAC, TPS, MAP, 02S, plenum, rotor ,cap, spark plugs, carbon canister, remove and cleaned TB, vaccum lines, reroute wires, compression check is good. I have no codes and still no solution.
There's gotta be a single point failure that triggers this sporadic iddle behavior.
I hate to be Captain Obvious here, but my truck was doing something very similar to what you all have been describing and the only thing wrong with it was a corroded battery cable and terminal. I try to stick with the KISS method when working on anything. Keep It Simple Stupid. Of course that could have a lot to do with my limited brain cells.
