Carpet soaked, not from coolant
Old Nov 11, 2009 | 09:25 PM
  #21
dodgeram07's Avatar
dodgeram07
Originally Posted by de8212
I went out earlier and noticed a good amount of h2o on the far left side of the bench seat and puddling down below on the side of the seat. Looked up and I believe this might be where I have a leak. How is this fixed? Does the black piece need to be replaced? Does it need silicone?
i just went and got some clear caulk and caulked around the window and kinda just like sealed up those holes on both sides and used my finger and a rag to try to keep it neat
but the first time i did it i used window rope (its kinda like play doh) in those holes
i hope this helps you out
Old Nov 12, 2009 | 08:05 AM
  #22
de8212's Avatar
de8212
Thanks dodgeram07. So, you had to do it twice? Once with window rope and once with caulk? Is caulk better than silicone?
Old Nov 12, 2009 | 09:33 AM
  #23
Sheriff420's Avatar
Sheriff420
you can remove the cowl.
Old Nov 13, 2009 | 03:41 PM
  #24
RamSport97's Avatar
RamSport97
I know, I should have elaborated more. I removed the plastic cowl, and took some RTV and sealed up the suspected body seem(very hard as you have to shove your arm through a tiny opening). I was in too much of a hurry to get it all back together and completely forgot to snap a pic. Anyway, no more trail of water. Before I could run water down around the air inlet duct, and see a small stream running down into my cab. So I hope it holds and keeps me dry for a while. Thanks for all the advice.
Old Nov 13, 2009 | 07:01 PM
  #25
dodgeram07's Avatar
dodgeram07
the window rope was just a quick fix but worked great/look bad
so when it warmed up outside i caulked it with silicone,,, it can get messy fast so take your time and have a rag and maybe sum goof off stuff
best of luck to you
and just keep a eye on it,, in a few months most likely in the summer time the heat will make it contack and you may need to add more
Old Nov 13, 2009 | 09:22 PM
  #26
tboss's Avatar
tboss
my mystery leak turned out to be the trash and gook that had built up in the fender under the pass side hindge,,if you look down into the cabvity where the hood hindge lives you will probably see it esp. if you park her under trees,,,cleaned mine out and nomore leak.. fashioned a piece of styrofoam to close the hole up enough to keep the leaves out and no more leak try it it might work for you also
