My Rebuild Thread
Old Nov 20, 2009 | 08:18 PM
  #31
95RAM360's Avatar
95RAM360
They also showed a demonsation on how it can travel through all the ports in the motor faster than most oils. How it can clean out the engine, and that theres a solution inside the oil that wraps around sludge and brings out when the oil is drained.
The class was about 8 months ago so give me time to remember more.
Old Nov 20, 2009 | 08:26 PM
  #32
J415's Avatar
J415
This is just me personally, but when a company gives a class about why there merchandise is the best, it really set's alarms off. I'm sure there are a lot of other brands that do the same thing. To each his own though.
Old Nov 21, 2009 | 07:18 AM
  #33
95RAM360's Avatar
95RAM360
true, he never demonstrated, royal puprle, etc. the "good brands" of oil. so i do somewhat agreee withyou, but it has been cleaning my engine
Old Nov 21, 2009 | 01:25 PM
  #34
cmckenna's Avatar
cmckenna
Default Fuel Injectors
Originally Posted by 95RAM360
ok so im making a thread because my truck is now parked, and im ready to start rebuiding. this is my list so far,
Coil- 45.99
[LEFT]http://www.summitracing.com/parts/ACC-140021/
Spark Plugs E3's- 5.99 ea.
CAT- 222.69
http://www.summitracing.com/parts/CTO-9647/?image=large
Hughes Plate- 86.00
http://www.hughesengines.com/Index/p...2&partid=22220
Tracbar- 70.00
http://cgi.ebay.com/ebaymotors/Track...Q5fAccessories
Intake- purchased , going to do kegger mod, and have port and polished
TB- purchased, shaved 2mm.
Fuel Injectors- need help with this.
Watch out when buying your FIs. Do not go with Accel. I have tested those as well as other bargain brands and, they are junk. The only ones to look for are the Bosch. Just be exactly sure to match up the flow rate, impedance and lbs / hr rating otherwise, your going to have issues.
Old Nov 21, 2009 | 02:40 PM
  #35
95RAM360's Avatar
95RAM360
im not getting the fuel injectors...im goingto run some cleaning solutionsthrough the truck to get my stock ones clean....for the meantime...
Old Nov 21, 2009 | 03:40 PM
  #36
zman17's Avatar
zman17
Retired Moderator - RIP
Buy a ***elry cleaner from Walmart, put some Techron Plus in it.
Old Nov 21, 2009 | 04:05 PM
  #37
cmckenna's Avatar
cmckenna
the wal-mart in my area does not carry them. (which is odd since i live in a big name city)
And the Mobil 1 class, they had visual demonstations with other synthetic oils, and then the Mobil 1. They used it on this little motor that would spin a dowel. then they would put weight on it, the other synthetics oils would make the dowel "seize" up after about 2-4 weights were put on (Penzoil, Castrol, Kendall, and Quaker State.) Then when the Mobil 1 was demonstated it was able to handle 6 of the weights, and was still going. the 7th made it "seize"
I guess that demonstates the "Under Load" and how it helps. There were other demonstations, but im not going to explain all of them...unless your interested
That test is bogus and is nothing short of a sales and marketing ploy to get you to buy their product.
However, there is an industry standard, four-ball wear test per ASTM D-4172 that shows Mobile 1 to be the least effective against engine wear as compared to to six other brands of motor oil.
Amsoil proved to show the least amount of wear and to provide the best lubrication per that test standard.
I would also watch out which kind of filter you choose to go with as some are very restrictive and prevent oil flow. Some K&N oil fiters have this issue. it had caused the oil pressure to go way up beyond what it should have been and impeded oil flow. FYI
Old Nov 21, 2009 | 04:08 PM
  #38
95RAM360's Avatar
95RAM360
^good to know, im going to try some amsoil next change, just to try it out...i use Mobil 1 filter my oil psi is 55 running, 45 idle
Old Nov 21, 2009 | 06:31 PM
  #39
95RAM360's Avatar
95RAM360
ok so my hughes plate is ordered, i second day aired it. (30 extra bucks...o well)
So hopefully i should have it Monday or Tueday!!!!cant wait to see how she runs with all this new stuff goin in!
Old Nov 21, 2009 | 06:38 PM
  #40
zman17's Avatar
zman17
The oil is not a prob, the filter however, as good as they may claim it is, I would still get a Wix or Baldwin or even NAPA Gold. And I may not have read the whole thread, But, didn't you just do the plenum with a Hughes plate? Now you are getting a second one?
