My Rebuild Thread
Old Nov 13, 2009 | 10:00 AM
95RAM360's Avatar
95RAM360
Default My Rebuild Thread
ok so im making a thread because my truck is now parked, and im ready to start rebuiding. this is my list so far,
Coil- 45.99
http://www.summitracing.com/parts/ACC-140021/
Spark Plugs E3's- 5.99 ea.
CAT- 222.69
http://www.summitracing.com/parts/CTO-9647/?image=large
Hughes Plate- 86.00
http://www.hughesengines.com/Index/p...2&partid=22220
Tracbar- 70.00
http://cgi.ebay.com/ebaymotors/Track...Q5fAccessories
Intake- purchased , going to do kegger mod, and have port and polished
TB- purchased, shaved 2mm.
Fuel Injectors- need help with this.
as you can see i need help finding a set of 8 fuel injectors for a good price. the cheapest i found was 408 for 4 (high performance), or 63 for one.
Im doing the 1.7's as well, and wheel bearings, tierods, hell the whole front ends geting replaced.
now any suggestions would be great on my journey. ill post pics, and show everything on how it goes with the rebuild.
Old Nov 13, 2009 | 10:06 AM
95RAM360's Avatar
95RAM360
and heres the parts checklist of everything im getting. the above is what im staring with.
Kegger Intake-Complete
Throttle Body- Complete
Fuel Injectors-
Coil-
Distributor Cap/ Rotor- Complete
Plugs-
Brake Lines-
Hughes Plenum reienforcment-
EGR Pipe-
CAT/02 Sensors-
Intake Gaskets-
Tie Rods-
Trac Bar-
Pitman Arm-
Wheel Bearings-
1.7 Roller Rockers-
Pass. Side Ball Joints-
Fuel Lines-
Harmonic Balancer-
Synthetic Oil Change-
Transmission flush/Filter-
Old Nov 13, 2009 | 06:56 PM
charlie1935's Avatar
charlie1935
I would go with a MSD coil instead the Accel.
Old Nov 13, 2009 | 07:51 PM
95RAM360's Avatar
95RAM360
10-4 any input would be great. i want to get this thing done right!
Old Nov 13, 2009 | 08:15 PM
J415's Avatar
J415
I can appreciate your enthusiasm, but take your time! Don't rush to get everything at once. Also, if your gonna buy stuff from Summit, do a Google search for "coupon code" in order to get good deals. I just ordered some stuff from there today and got 10% off of my order.
Old Nov 13, 2009 | 08:43 PM
Twisted Metal's Avatar
Twisted Metal
Unless you are having problems with the injectors, just a good cleaning in an unltarsonic(***erly cleaner) cleaner should suffice. Replace the o-rings for the injectors before installing them in the kegger. +1 on the MSD coil, and spend the extra for the adapter harness, its an Accel part actually. Only other advice than what has been offered so far is CLEAN CLEAN CLEAN. Clean everything and anything. Chase out threads, degrease, you get the idea. Might be more time, but in the long run, you'll be done once, done right. Good luck with it, pics would be nice, and keep us posted.
Old Nov 13, 2009 | 09:11 PM
lastrights's Avatar
lastrights
what you need a coil for ??
Old Nov 14, 2009 | 12:39 AM
dodgeram07's Avatar
dodgeram07
Harmonic Balancer i dont think you need a new
Hughes Plate- 86.00,,,,,,,,, i thought you just did this?
Old Nov 14, 2009 | 05:18 AM
Sheriff420's Avatar
Sheriff420
http://www.summitracing.com/parts/MP...5/?image=large
Old Nov 14, 2009 | 03:39 PM
95RAM360's Avatar
95RAM360
i did, but i got a kegger from J415, and my best friend has a ram with a REALLY bad plenum, so im selling him my manifold with the hughes for 100 bucks.
and im getting a coil because i want a FULL tune up done to it. I love my truck and plan on having it a LONG time, so only the best for her.
