DIY plenum fix ??
Old Nov 14, 2009 | 04:34 PM
clap's Avatar
clap
Default DIY plenum fix ??
Can anybody tell me what this DIY fix does for the truck? Benifits ?
Thanks in advance Dave C
Old Nov 14, 2009 | 04:56 PM
95RAM360's Avatar
95RAM360
the plenum being blown allows oil to enter the intake manifold, causing the plugs to foul, kill o2 sensors, clog up the cat, cuase horrible performace, burn oil, and give very poor gas milage.
its the fact that its aluminum to steel, so with the temps geting very hot, the metals expand differently. causing the pressure to eventually blow out the gasket.
Your best best is to go with the Hughes Plenum Reienforcment Kit. This will totally eliminate the plenum for good. and give you better performance than stock. (i have it and it does give you better power)
All in all its not a hard job to do. it took me 18 hours, including 6-7 of cleaning stuff up. and 2 hours of BSing because when i put it back together, my fuel injecotr o-rings were leaking, and i wired up the plug wires wrong on the dist. cap.
So it is a fairly easy job, takes basic tools, all you need for specialty tools is a fuel line disconnect. but you will noticed a hell of a difference.
YES YES YES it will benifit. but at the same time you should change Dist. cap/rotor, plugs/wires, 02 sensors. and gut the cat or buy a new one. your truck will thank you.
Also you will need Intake gaskets, and bolts for the intake bolts are TTY (torque to yeild.) Fromhughes you can get gaskets and bolts for about 45 bucks. Go anywhere else the Bolts alone are 50.
Hughes Plate- 86.00
Hughes Intake Gaskets/Bolt- 45.00
Dist. cap/Rotor- around 25.00
CAT (if you want performance from summit) 222.69
and thes rest is whatever you want to get.
Old Nov 14, 2009 | 07:10 PM
clap's Avatar
clap
Do you have a link for the Hughes stuff
Old Nov 14, 2009 | 07:56 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Just go to http://www.hughesengines.com
Old Nov 14, 2009 | 08:05 PM
95RAM360's Avatar
95RAM360
http://summitracing.com is where you can go for the CAT/ tune up parts
Old Nov 14, 2009 | 09:54 PM
JackJ's Avatar
JackJ
I am a bit confused on what you mean by Oil in the throttle body, my butterfly valves are coated in an oily carbon build up, is that what is meant by this?
Old Nov 14, 2009 | 10:34 PM
95RAM360's Avatar
95RAM360
look into te manifold with a flashlight. its through the TB you have to look. and yes, Oil coating n Tb is a definate sign
