Can i swap an engine from a 95 jeep cherokee into a 98 dodge ram 1500?
I just recently bought a 98 dodge ram from a fellow to find I was decived and the engine has a blown head gasket. This has always been my ideal truck and do not wish to scrap it, so I would like to swap out the engine and i have a 318 5.2 v8 out of a 95 jeep grand cherokee. Will this be a compatible swap? Please any help here would be greatly appreciated!
it currently runs and drives, not even sure what is wrong with it for sure, was loosing water and alot of white smoke from the exhaust,at one point if driven any distance and then had to sit in traffic for a while idleing it would lose oil pressure until i dropped it into nutruel, and the oil pressure guage would go back up and i would continue to drive so i could get it home. I poured in a gasket sealer into the radiator and i stopped loosing water.
The following users liked this post:
Sean Nicholls (04-07-2021)
No problem. The 95 is OBD1 and probably also has an egr on it. The 98 is obd2 with no egr. Which is why you have to swap the manifold and a few other sensors. Also do a search here for "plenum" , for info on that and replacing the lower plate on it while you have it apart. And btw, we are talking about two 318's with auto tranny's correct?
Trending Topics
