5.9 needing replacement
Old Nov 16, 2009 | 12:29 PM
big96ram's Avatar
big96ram
Default 5.9 needing replacement
well guys i have a 95 ram with the 5.9 magnum and its shot. the valves and rings are toast and is the head gasket and probably some other gaskets. this makes me mad cuz this truck only has 110k on it if that cuz my odometers off. so i am wondering if i could swap in a 5.2 from like a 98 without having to change to much wiring and if the transmissions would match up? let me know im in the market for an engine now and if you have a good running one and your in michigan pm me a price. also if you know of any good shops in michigan to look for one at let me know. i just need to get this dang thing fixed, luckily i have a backup truck to drive.
Old Nov 16, 2009 | 12:47 PM
95RAM360's Avatar
95RAM360
i guess you need to swap torque convertors
and try
http://car-part.com
Old Nov 16, 2009 | 03:51 PM
RedRigRon's Avatar
RedRigRon
^+1 you also can try >Here< for used engines. I've heard good and very little bad things about them, but the warranty might be worth it.
edit:
I took another look closely, they have Installation available, Free Shipping within continental U.S., Three (3) year unlimited mileage warranty
Old Nov 16, 2009 | 04:14 PM
lastrights's Avatar
lastrights
why dont you just get new heads from clearwater http://cgi.ebay.com/ebaymotors/NEW-D...item563344b08d
Old Nov 17, 2009 | 06:53 PM
big96ram's Avatar
big96ram
alright ill look into those sites. and is the only thing the torque convertor? and im just gonna try and find a used 318 from a junkyard or something with like a 90 day warranty and see what comes up. i like the 318 beter than the 360 anyways
Old Nov 17, 2009 | 06:59 PM
Miami_Son's Avatar
Miami_Son
You might try doing a search. There are a number of engine swap threads already in here.
Old Nov 17, 2009 | 09:48 PM
dhvaughan's Avatar
dhvaughan
i'd stick with the 5.9. otherwise i think you end up with problems with computer, flex plate or torque converter, harmonic balancer.
you probably already know this but 94-95 is OBD-I and 96+ is OBD-II. I think the only difference is intake and sensors. so you may have to put your 95 intake and sensors on anything outside of 94/95.
Old Nov 18, 2009 | 12:09 PM
95MaroonMonster's Avatar
95MaroonMonster
id swap another 5.9 in, but the other 5.9 hehe
Old Nov 18, 2009 | 12:11 PM
95RAM360's Avatar
95RAM360
some 96's are still classified as OBD1, 1997 is when all were changed
