Fuel sync?? Distributor off??
Old Nov 20, 2009 | 10:07 AM
Twisted Metal's Avatar
Twisted Metal
Originally Posted by Sheriff420
gotcha.
why do they call it a 408 if its actually a 410?
Becasue you can have a 408 without doing any work to the cylinders themselves. A 408 is still the same 360 block with a different crank and rods.
Old Nov 20, 2009 | 02:03 PM
Activate's Avatar
Activate
Thanks for the answers,
I also thought it was 180 off, but with the tdc mark on the Balancer and at the timingmark on the timingchaincover, the distributor is at the first cylinder so that must be good then?
I also made a mark on the housing and intake before I take it off it is now at the same spot.
Thanks and greetings,
Erik
Old Nov 20, 2009 | 03:13 PM
95RAM360's Avatar
95RAM360
on the timing chain, there should be a discolored link/ a dot on one of the lnks tht is supposed to line up with a timing mark. Is that lined up?
Old Nov 20, 2009 | 06:47 PM
Activate's Avatar
Activate
Hello 95RAM360,
Thanks for the answer,
I have bought a new cam and a new double timingchain so there are coloured dots on it.
I have the dots on the crank and cam set in line.
Erik.
Old Nov 20, 2009 | 08:05 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You can't just go by the mark! You have to make sure the #1 is on compression stroke.
Old Nov 21, 2009 | 08:26 AM
aim4squirrels's Avatar
aim4squirrels
try checking this article out and see if it rings a bell:
http://www.bionicdodge.com/Download/...uel%20Sync.pdf
Old Nov 22, 2009 | 04:54 AM
Activate's Avatar
Activate
It runs!!!
Thanks for all the help!
I have done it different :
I had already a Megasquirt on my Dodge to control the Propane injectors.
The Ms can also control 8 Coils!
So I have taken 8 Coils from an Ls1 (Coil near plug) and put them on the Dodge.
The Ms controls them now and it is working fine!
I think the feulsync must be also good because I have no problems att all anymore at this moment.
I left the orignbal distributor cap on, removed the wires to the plugs and let the original coil aso sit to avoid getting codes!!!
Thanks for the help!
Erik.
Old Nov 22, 2009 | 09:43 AM
aim4squirrels
Wow, that's a unique setup. I'd love to see some pictures of that engine bay.
Old Nov 22, 2009 | 11:59 AM
Activate's Avatar
Activate
I will made some pictures tommorow it is now dark here in The Netherlands....
It is running nice!!
I am still looking for the dustcover for the tranny I can not find it anymore.
There are no dealers for this pickup in The Netherlands so difficult to get....
Old Nov 22, 2009 | 12:01 PM
Activate's Avatar
Activate
I also canhange the calipers and pads to a set of a 2500 with powerslot rotors for a 1500.
It fits!!
I can not tell if it is already better because of the break in and I want to do it right.
The pedaltravel is just like before.
Greetings,
Erik.
