4x4 front axle seals
Old Nov 22, 2009 | 09:45 PM
silverbullet-dodgeram's Avatar
Default 4x4 front axle seals
well my truck has been setting for a few days now, and i got to looking, and there is gear oil steadily dripping out of the passenger side seal i was just wondering if this is just a seal or something more, and how hard is this to fix. is this something the average person can do and, how much do seals run?
Old Nov 22, 2009 | 09:46 PM
95RAM360's Avatar
95RAM360
seals are cheap, under 20 bucks for a cheapy, and since yours is on the pass. side, its a piece of cake. Do a search, there a very well detailed write up on how to do both of them.
Old Nov 22, 2009 | 10:02 PM
dodge15004x45.9's Avatar
dodge15004x45.9
http://www.pavementsucks.com/tech-article-3.html
Old Nov 23, 2009 | 10:55 AM
Sheriff420's Avatar
Sheriff420
that one is easy. the pavement sucks article doesn't have a picture of the seal driver you will need.
pull the hub, axle and cad unit and the seal is right there inside the cads hole. pop it out with a piece of pipe and drive the new one in and put it back together. then put 5oz. of diff fluid through the 4x4 indicator switch and you're done.
