serpentine belt, smells like burning rubber
Old Nov 23, 2009 | 05:09 PM
xray99's Avatar
xray99
Well, update when you find out anything.
This belt was an exact replacement installed with ribs down, right ?
Old Nov 25, 2009 | 01:05 AM
rczanstke's Avatar
rczanstke
Yes, exact replacement ribs down. Took it off and put it back on, and now the smell is no longer there. Must have done something wrong the first time. Idk.
Old Dec 9, 2022 | 12:56 PM
Purebliss68's Avatar
Purebliss68
Default Let it adjust itself?
[QUOTE=95RAM360;1884110]the thensioner pulley could be to far back. did you let it tension itself when you changed thebelt or did you pull the tensioner back?
HAVE THE SAME ISSUE, I PULLED THE TENSIONER PULL BACK. IS THIS NOT HOW YOU DO IT? "HOW WOULD I LET IT TENSION ITSELF BACK"? PLS AND TY!!
Old Dec 10, 2022 | 12:03 PM
Keith_L's Avatar
Keith_L
[QUOTE=Purebliss68;3556513]
The tensioner is spring loaded, you don't really have any say over what it does once you let off it. They can get weak and not return to enough tension, but that's about it.
I had one on a '98 just kinda get stiff and where ever you cranked it is where it stayed, but that's not how it's supposed to work and not reliable because enough force would back it off and then absent any spring pressure it wouldn't return to proper tension.
Old Mar 12, 2023 | 08:59 PM
Just saying's Avatar
Just saying
Default Sometimes belts stink for the first day
It's because the belt is new but it will stop stinking later
