superchips
Old Nov 29, 2009 | 12:29 AM
jasonw's Avatar
jasonw
Site Moderator
Originally Posted by 004x41500
while mostly true, there are certain ones where they dont ping, such as mine, it dont start pingin till around 4400RPM but by the point its shifting.
And what octane level do you have it set at, 87 or 92? 3923 plugs as well, by chance?
Sheriff: As far as your stealership reprogramming it for you... they are going against Chrysler corporate by doing that. Did you explain to them exactly what you meant by "stock timing", otherwise they may think you had it custom programmed and are wanting the death flash reinstalled.
Old Nov 29, 2009 | 12:44 AM
004x41500's Avatar
004x41500
on tow it dont ping at all, but on 93 it pings around 4400(with 87 gas) as i said before and nope, just some MSD 8MM wires, BWD Dist Cap/Rotor( i know but i was short on cahs and needed it right away) and bosch copper plus plugs.
Old Nov 29, 2009 | 01:01 AM
Sheriff420's Avatar
Sheriff420
that's a good point. i specifically asked if they could advance the timing to set it back to what it was from the factory. i guess i should call again with the death flash tsb number ready to make sure that they don't think i'm talking about setting it to that.
Old Nov 29, 2009 | 07:36 PM
dhvaughan's Avatar
dhvaughan
dealer cannot/will not reinstall pcm programming other than the "latest revision" from Dodge. you're wasting your time talking to them. the original timing version has been obsoleted. kaput. gone.
superchips is your friend.
Old Nov 29, 2009 | 08:37 PM
Twisted Metal's Avatar
Twisted Metal
As usual +1 for Vaughn. Sheriff, you'd be better off taking the PCM out and smashing it with a ball peen hammer. Trying to get the Stealership to do anything PCM related is completely useless. On my 99 2500 I had your same thought, even had an "inside connection" at my local stealership. 3 different trips, and not a damn thing, It actually ran worse.
Superchips is my friend too.
Old Nov 29, 2009 | 09:00 PM
360mag45's Avatar
360mag45
Hope you have a Hughes plenum kit installed (or equivalent), otherwise the Superchips (or any other good tuner) will make your engine ping like crazy.
wht do you mean by equivalent a good plenum gasket? cause i have been thincking of geting a superchips for mine but i don't want it to ping.
also i see a ton of superchips out there for 1998 to 01 do they make a programmer for a 97
Old Nov 29, 2009 | 09:33 PM
004x41500's Avatar
004x41500
unfortunatly no. the reason they didnt is because the 97 was a mix of OBD1 and OBD2 then 98 was straight OBD2(per federal regulations) i think hypertech makes one though...not 100% sure.
Old Nov 29, 2009 | 09:37 PM
360mag45's Avatar
360mag45
so if its a 1997 obd2 then that programmer for a 1998 well work
Old Nov 29, 2009 | 09:52 PM
004x41500's Avatar
004x41500
thats a very good question...if you know someone with a 2nd gen and a superchips you might be able to try to see if it works.
Old Nov 29, 2009 | 10:13 PM
360mag45's Avatar
360mag45
dose anyone know a way to tell if its obd1 or obd2
