My thanksgiving brake project
Old Nov 29, 2009 | 11:33 PM
360mag45's Avatar
360mag45
to make it easyer i took the rad out so i could sit in the engin bay and work made life easy also if your gonna do don't forget were **** gose or your gonna be up **** creek and sinking fast lol
Old Nov 29, 2009 | 11:48 PM
Cheat's Avatar
Cheat
what did you paint your intake with?
Old Nov 30, 2009 | 07:30 AM
dhvaughan's Avatar
dhvaughan
Originally Posted by rwilhelms
Do you have to take the throttlebody all the way off to see if its leaking.
i tried to do it w/o removing TB and couldn't really see anything. later on when i installed a hypertech it pinged like crazy. so i removed the TB and checked again and could see a lot better - i had a puddle of oil at the rear.
you can pretty much bet on this - if its never been fixed, and it feels like a turd. its leaking.
Old Nov 30, 2009 | 08:11 AM
zman17's Avatar
zman17
Retired Moderator - RIP
+1.... remove the TB to check for oil.
Old Nov 30, 2009 | 08:27 AM
moparama's Avatar
moparama
worst case all it will cost you is a new gasket for TB if it ok down in there. And if its oily need to take it of anyway to make it easier to pull the keg out anyway
Old Nov 30, 2009 | 08:42 AM
Sheriff420's Avatar
Sheriff420
hammer down, that gasket on yours looks like the first felpro that i looked at. i decided not to get it and then the next day i got a different felpro gasket that is rubber on both sides.
and with the throttle body off you have a nice handle to take the intake out via the TB holes.
Old Nov 30, 2009 | 08:51 AM
Hammer Down's Avatar
Hammer Down
Duplicolor Engine primer and enamel.
And Sherrif, I ended up using nothing but felpro gaskets when I put everything back together. I didn't like the cheap, plastic gasket that came with the hughs kit.
The truck runs great now after I replaced the TPS, which decided to go out at the same time. I havn't filled back up yet or run the truck long enough for the computer to relearn, so I havn't noticed much difference yet, but I will keep you guys updated.
Old Dec 1, 2009 | 12:29 AM
Cheat's Avatar
Cheat
Well I would like to do this to my truck, I just hate to have 6 different shades of blue on the truck, So do you think that if i coat it with the black engine enamel and then go for the trucks paint would it stick? And do you think it would hold up?
Thanks,
Cheat.
Old Dec 1, 2009 | 08:20 AM
moparama's Avatar
moparama
Well I dont think it would. Besides puting your final color over a black base will slightly darken your top color. And also to you may not get a good bond between the two diff. paint types. and you would want to scuff the engine enamel to remove any type of gloss so you get it to stick better
Old Dec 1, 2009 | 10:09 AM
Sheriff420's Avatar
Sheriff420
Originally Posted by Hammer Down
And Sheriff, I ended up using nothing but felpro gaskets when I put everything back together. I didn't like the cheap, plastic gasket that came with the hughes kit.
my hughes kit came with the carbon type felpro manifold gaskets and some rubber wrapped metal end seals. then the pan it self had that crap metal compression gasket so i got the felpro metal with rubber on both sides type for the belly pan.
i was saying that your original gasket is like the first one i looked at, carbon with intermittent lines of blue rubber on each side. i said no thank you to that. and its a good thing too after seeing your original leaky gasket.
