My thanksgiving brake project
Old Dec 1, 2009 | 09:05 PM
  #21
RamSport97's Avatar
RamSport97
I just ordered the hughes plenum fix kit today. So you guys are saying to use a different belly pan gasket then what comes in the kit? Do you guys have part numbers and would Autozone, Advance, or Napa carry the Felpro?
Old Dec 1, 2009 | 09:44 PM
  #22
Cheat's Avatar
Cheat
Originally Posted by moparama
Well I dont think it would. Besides puting your final color over a black base will slightly darken your top color. And also to you may not get a good bond between the two diff. paint types. and you would want to scuff the engine enamel to remove any type of gloss so you get it to stick better
Well i would scuff the engine enamel. But would it stick after that? And if so would it burn off?
Old Dec 2, 2009 | 09:20 AM
  #23
Hammer Down's Avatar
Hammer Down
Here you go. http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Intake-Manifold-Gasket-Set-Felpro_15780605-P_102_R%7CGRPGASKAMS_842490158______
I'm not saying that the gasket that comes with the kit wouldn't work. Its just that the FelPro gasket has a lot more substance to it and since the belly pan gasket comes with the FelPro intake gasket set, why not use the better one?
Old Dec 2, 2009 | 01:04 PM
  #24
RamSport97's Avatar
RamSport97
Makes sense. Thanks buddy!
Your truck looks awesome by the way.
Old Dec 3, 2009 | 11:40 PM
  #25
RamSport97's Avatar
RamSport97
Alright, if the rain brakes tomorrow I am going to tear her down. I have a question about the intake manifold Torque to Yield bolts. I understand the general opinion is to always replace these and not reuse them. Well, I am having a hard time finding replacement TTY bolts, none of my local auto parts stores carry them, would the Dealer have them in stock? Has anyone just went ahead and re used them without failure? And if I had to, could I just go down to Ace and just replace them all with solid Stainless Steel bolts?
Old Dec 4, 2009 | 08:28 AM
  #26
Hammer Down
Thankyou very much!
About the TTY bolts, I had to order them from Advance. It only took 1 day for them to arrive. DO NOT reuse the old bolts. They change shape after they are used. Hardware bolts could possibly work, but I would play it safe and order some. FelPro has those too lol.
Old Dec 4, 2009 | 08:33 AM
  #27
Twisted Metal's Avatar
Twisted Metal
Might be a little after the fact, but both Hughes and APS offer install kits for the plate that come with new TTY bolts for it. As well as new TTY's for the intake.
Old Dec 4, 2009 | 10:20 AM
  #28
Hammer Down
You're apsolutely right! I forgot about that.
Old Dec 4, 2009 | 09:42 PM
  #29
RamSport97's Avatar
RamSport97
Alright thanks fellas. I went ahead and ordered the felpro gaskets, and felpro manifold bolts today at Advance, they will be in tomorrow morning and hopefully I can knock out the plenum fix in one day.
Old Dec 5, 2009 | 09:28 AM
  #30
Sheriff420's Avatar
Sheriff420
you can knock it out in a day if you don't start 2 hours before dark like i did. then start again the next day only to give up after 45 minutes to go fishing. then start again the next day an hour before dark.
it took me a few days.
