Harmonic balancer oil leak?
Old Dec 1, 2009 | 08:07 AM
charlie1935's Avatar
charlie1935
Seems like they used be called vibration dampeners because that is what they do.
On an externally balanced engine the dampener is not perfectly balanced, it will have a heavy side to compensate for an non balanced crankshaft in the engine.
Maybe someone else will jump in and do a better job of explaining than I can.
Old Dec 1, 2009 | 08:15 AM
moparama's Avatar
moparama
Ah yes you are right that is what they called it but as far as it sliding into the front seal they are same. they both wear and they both need inspection when replacing that seal
Old Dec 1, 2009 | 08:42 AM
95RAM360's Avatar
95RAM360
Originally Posted by moparama
5.2 dont have HB? Since when cuz mine has a big *** thing on the front of crank that surely resembles one.
ok way to be an ***, but i was just asking if it had one.
the difference between a question and a statement is that a question would like an answer, and a statement has the answer. so i dont think i said they dont have one. i believe i was asking dumbass
Old Dec 1, 2009 | 03:14 PM
helms's Avatar
helms
the 5.2L is internally balanced so the HB is statically balanced, its job is to absorb crankshaft harmonics. A 5.9L is externally balanced, the HB on this engine is basically the same as the 5.2 except it has a counterweight on it. also the 5.9 will have a counterwieght on the opposite side of rotation mounted on the flywheel or flexplate.
Old Dec 1, 2009 | 06:45 PM
dhvaughan's Avatar
dhvaughan
5.2 does have HB.
i don't know that its possible to put the seal in wrong. it sort of only goes one way.
it might need a sleeve. its also possible that it just failed...
i put new seals on the rear axles of my daughter's 4runner. one worked like it was supposed to and the other one leaked and i had to replace it again. don't know why, but it just did.
$hit, that's a lot of work to replace that seal again.
Old Dec 4, 2009 | 08:01 AM
95RAM360's Avatar
95RAM360
im sorry for how i acted before.....i had my maxima get towed and i had to pay 350 bucks to bail it out of the colission center...(didnt have registered plates.) And i didnt have the money to throw out like that with x-mas rightaround the corner.
So as you can tell i was pissd that day...so im sorry for my remarks.
Old Dec 4, 2009 | 09:23 AM
charlie1935
Think nothing of it.
I've been pissed off more times than I can remember in my 74 years.
Old Dec 4, 2009 | 11:28 AM
95RAM360's Avatar
95RAM360
i was takin my frustrations out on everyone that day...i almost punched the cop that had my car towed, i was so mad.
I used to do some MMA (mixed Martial arts for those who didnt know) and i use to take out all my aggresions in my fights. well i have a daughter now, i dont fight anymore, so i have no way to vent my angers....that cop almost got laid out lol..i have a very bad temper
