Truck lost power while hauling uphill
Old Nov 30, 2009 | 06:41 PM
Jay1751's Avatar
Jay1751
Unhappy Truck lost power while hauling uphill
Ok so i have an 01 ram 1500 360.. Heres a little background info first.. i was towing mine and my buddies quads this weekend out to go riding.. i was goin up a hill (70mph, 3000rpm) when the truck started shuttering and losing power. my check engine light started flashing.. then it started miss firing.
i made it home later that day hooked it up to the little diagnostic comp- it read random misfire.. i pulled the cap and rotor (which are only 3months old along with plugs and wires) to find the rotor was worn to hell and the rivet holdin the contact was loose. I replaced both cap and rotor, cleared the code and the truck runs a little better but still idles like crap. its idling like its missing but no longer reading a code.. i took it out for a drive trying to see if anything would pop up.. nothing.. it still runs very rough (especially when taking off from a dead stop).. any ideas on what it could be would be much appreciated.. tomorrow morning I'm going to check each cylinder for spark individually and then move on towards the injectors and take it from there
-Jay-
Old Nov 30, 2009 | 06:43 PM
PurplDodge's Avatar
PurplDodge
I would do as you are saying, check each cylinder for spark then go from there. Good luck!
Old Nov 30, 2009 | 06:44 PM
Jay1751's Avatar
Jay1751
thanks.. im hoping i figure it out
Old Nov 30, 2009 | 06:46 PM
moparama's Avatar
moparama
Did you do the plenum check? rough idle maybe vacuum leak?
Old Nov 30, 2009 | 06:48 PM
Twisted Metal's Avatar
Twisted Metal
Check the plugs while your testing spark. Check the plug wires themselves for burns or arcing marks. Reroute the per TSB to prevent crossfiring.
Old Nov 30, 2009 | 06:53 PM
moparama's Avatar
moparama
Is there a link for TSB routing?
Old Nov 30, 2009 | 07:53 PM
Jay1751's Avatar
Jay1751
ok i know i sound stupid but what is a plenum check?.. tomorrow morning im going to check each individual plug and wire. pouring down rain where i am this afternoon and i can fit my truck in my garage (lifted too high )
Old Nov 30, 2009 | 07:56 PM
dodge15004x45.9's Avatar
dodge15004x45.9
You know that keg looking thing. Its under there. There is a gasket that is PRONE to breaking.
Old Nov 30, 2009 | 07:57 PM
Jay1751's Avatar
Jay1751
ok but what is it ?
Old Nov 30, 2009 | 08:01 PM
dodge15004x45.9
A gasket that blows. Which cost you power and mpg's and makes our trucks run ruff.
