whats your plans for the 2010
Few things on my list, I wont be restarting work till early spring.
Make brackets for the intercooler, fuel pump, controller, filters, regulator, delete box & pwdrct them.
may pwdrct the u/l c arms, leafs, swaybar.
extend stripes onto the rollpan (pc brackets also) & paint/match the chrome tailights
install mtr, trans & wiring harness,
plumb the fuel system
get off the fence & mount the fuel cell either ontop or under the bed. Lot more work under but will look so much better/cleaner.
Engine- Kegger Mod/ Poorman's TB, Shorties,Y-Pipe,Exhaust, maybe 1.7's
Trans- New bigger cooler, and trans temp gauge
Exterior- Roll pan, new color matched grille, fix rust and repaint
Now mind you, Its quite possible I will be posting this exact same list roughtly one year from now. But its a plan none the less.
Best plan yet...good luck! (Always first on my mind)
However theres a few worn items that need attention.
Ball joints
Hub bearings
Brakes including Calipers and
new stainless lines.
I'd planned on dropping my front suspension and sending
a few parts to the powder coater.
Redo the front seats
Theres a few other non esentials I'd to add, but that will be very dependent on the economy. So far it isn't looking good.
hopefully almost nothing, she should be about done by then, i hope
if not, ill be finishing up with installing gooseneck hitch and trailer brakes/wiring and the rear bumper
and some odds n ends (maroon's gonna look good again, and run like the bat outta hell it was when i bought her)
1.7 RR's
Replace everything in front end
Axle Seals in front
New Heads/ head gaskets
Header back exhaust with dual conversion
camshaft
some nice beefy tires
thats all i want to get done as of now....Its what i wanted to do im my rebuild that im doing. Should have all that done by May.
Axle Seals in front
camshaft
