Tranny Experts chime in please.
Old Dec 5, 2009 | 06:53 PM
95RAM360's Avatar
95RAM360
Originally Posted by J415
$675 for a rebuild?!?! You can almost COUNT on it taking a dump on you REEEAAAL fast!
lol
any way you can see a recipt so you know hes not BSing you.
when i bought my truck he told me the rear end had 4.10's just installed 5000 miles before i bought it, had a new rebuilt tranny, and fuel pump i asked for recipts and this is what i got
4.10 gears- 1450.00
Tranny Rebuild- (7500 miles before i bought it) 2299.00
Fuel Pump- 295.00
he had all the recipts and DID prove it to me
Old Dec 6, 2009 | 04:23 AM
1fast2liter's Avatar
1fast2liter
hey 95 do you have a 2wheekor 4wheel drive
Old Dec 6, 2009 | 07:05 AM
95RAM360's Avatar
95RAM360
4x4....its in my sig
Old Dec 6, 2009 | 02:30 PM
Als70ss's Avatar
Als70ss
Originally Posted by 95RAM360
lol
4.10 gears- 1450.00
Fuel Pump- 295.00
The Guy I bought the truck from is a Paster and I found a bill of sales and he bought the truck with a blown tranny and hail damage he fixed the hail damage and he called around and found the cheapest rebuild. Also he repaired the dents because He also does paint less dent removal.
Old Dec 6, 2009 | 04:25 PM
Augiedoggy's Avatar
Augiedoggy
Originally Posted by transguy37
If it's taking off in second,the governor pressure sensor and solenoid are bad.They are on the valve body,not hard to change.
I had a bad gov pressure soleniod and sensor and if it is bad you will get a 1741 error on a code reader....also my tranny went into limp home mode....it wouldnt shift out 2nd gear...only had first and second...you could sometimes get it to shift by punching the pedal to the floor momentarily.
Old Dec 6, 2009 | 06:31 PM
xray99's Avatar
xray99
2 quarts low is pretty drastic, if you were running that low for any length of time you probably killed the tranny from excess heat.
Old Feb 8, 2010 | 02:30 PM
Als70ss's Avatar
Als70ss
Thanks to everybody for your input. I ended up putting in a a salvage yard tranny with a 2 year warranty they gave me a new filter. I had to flush the tranny lines put a new cooler and bypass the radiator which already was and i installed a temp gauge and a cooling fan on the cooler. I have had it up to 180 and then I run low range while plowing and when it drops below 160 i go to 4 high.
