differentials
differentials
Front: i recently had a my dana 44's spider gears shred when i needed them most (in the mud, stuck at that), i have a open diff in it now, i went to the jy and pulled a diff on a dana 44 for it's spider gears, it was an lsd.
Would the spider gears be able to bolt up or do i need to keep looking?
Back: is there a vin code or anywhere stamped on the truck if my truck has a lsd or open diff. it's a 96 1500 4x4 slt tow package, if that's relevant.
You can request a build sheet and it'll tell you.
http://www-5.dodge.com/wccsapp/unive...ull&category=U
and your entire front end from doors forward is off another truck?
I already pulled the cover to find I had an LSD rear....(and had to have it rebuilt as it soft of exploded and parts where stuck to the magnet in the pumpkin...I've yet to confirm I have 4.56 gears in both axles...(i got to try the chalk trick someone told me about to check it to be safe I know the rear is 4.56)...
Trending Topics
