Water gurgling sound
Old Dec 7, 2009 | 03:46 PM
rideordie's Avatar
rideordie
I have this too..thought I was crazy the first few times.
Maybe I'll try getting air out some day
Old Dec 8, 2009 | 01:06 PM
97r/tram's Avatar
97r/tram
My truck used to do this on cold startup, but the other day I found that my coolant reservoir was empty and I was a gallon low on coolant. Obviously the air had come out of wherever it was trapped and pulled spare coolant in. It doesn't make that sound now. Just a little fyi incase you check the coolant and you're low a gallon and wonder where the hell it went.
Old Nov 16, 2010 | 09:11 PM
blackknight87's Avatar
blackknight87
sorry to bring up an old post, but my 97 dakota does this too. I only hear it when i press the accelerator tho. and it goes away when i let off.
should i attempt to air out of the system, by parkin on a steep angle and running the truck then adding coolant til its full?
Old Nov 16, 2010 | 09:25 PM
slider15004x4's Avatar
slider15004x4
That is what I tried and I still have the sound and mine also is only when I push the gas pedal.
Old Nov 16, 2010 | 11:36 PM
Road Hammer's Avatar
Road Hammer
I've only had my truck about 3 months now. I also get the gurgle, but seems to be only when it's been plugged in (block heater), and it does it when I first start to drive away, but only for about 5 secs, then it's gone. I have no coolant loss and lots of heat from the heater. I thought if I had air in the cooling system I would have a no-heat condition? No?
Old Nov 19, 2010 | 01:12 PM
murren's Avatar
murren
My 97 did the same thing for the longest time. Bled the system by parking on an incline, opened radiator cap, started it up and let it run..Keep adding coolant until it stays up to the neck, and don't forget to keep the reservior filled..seemed to help, cause I haven't heard it since.
Old Nov 20, 2010 | 02:50 PM
blackknight87
well now i have a water pump problem. Im leaking coolant all over my garage floor from the water pump.....soooo i gotta get that fixed.
Old Nov 21, 2010 | 03:05 PM
slider15004x4
Surprise, surprise. Mine is now leaking also. Just noticed it this afternoon.
Old Nov 21, 2010 | 05:05 PM
blackknight87
yea and i just bought this truck 2 weeks ago. of course it doest start leaking til i have it in the garage....
