Broken Spark plug
Old Dec 7, 2009 | 10:05 AM
Erik Kuijvenhoven's Avatar
Erik Kuijvenhoven
Default Broken Spark plug
So I have owned my truck since 2003 its a 1998 I never did the plugs until last Jan I found my #8 plug had a piece missing I thought I had blown the piece out with some air since it was running fine, But obviously not The trucks #8 cylinder has had 50PSI compression since Jan 09, and has been ticking as well I figure its a collapsed valve, Anyone have any Ideas as to why its been running for 11 months problem free and then yesterday its like on the highway the truck has the hiccups it holds back as if its not getting fuel or air or something is bogging the motor down UI have been very gentle on her since Jan I know the motor is shot but I thought it would last a bit longer than11 months since its only been my backup truck it hasn't even ran 8 k , Anyways love to hear some opinions on what i should do fix it or scrap it Anyone want a parts truck?
Old Dec 7, 2009 | 11:19 AM
lastrights's Avatar
lastrights
maybe low compression on that cylender cant keep up with the others , or blown head
Old Dec 7, 2009 | 08:45 PM
dhvaughan's Avatar
dhvaughan
did you replace plug number 8 ? maybe the "broken piece" finally gave it up.
also recheck compression on #8. see if its the same 50 psi, or did it get worse.
Old Dec 7, 2009 | 08:48 PM
95RAM360's Avatar
95RAM360
+1 id do that first, and let us know
Old Dec 7, 2009 | 10:43 PM
Erik Kuijvenhoven
Will Do, I am buying a 1996 dodge ram 5.9, are all the parts interchangeable or no? I got a 1998 with 1999 Brakes the truck was built in DEC of 1998 and ended up with the 1999 front brake pad backing clips So i dont know what else is from a 1999
Thank you for the Replies
Last edited by Erik Kuijvenhoven; Dec 7, 2009 at 10:50 PM. Reason: needed a bit more info
