Lift Questions
Old Dec 8, 2009 | 01:55 AM
helms's Avatar
helms
Originally Posted by moparama
I understand that with bigger tires, but lets think, stock tires are 265 which is what 31 or 32's even if you put on 40" tires still only 4" more. Hey dont get me wrong its cool in all but alot of money to gain 4" of clearance dont ya think?
bigger tires dont only help with axle clearance. Have you ever been rolling around on your creeper and hit a nut or bolt that was lying on the ground? it locks the wheel up and you skid to a halt. Now try rolling over the same nut or bolt with a 35" tire. The comparison is a little extreme, but im sure you get the idea.
Old Dec 8, 2009 | 05:24 PM
chet's Avatar
chet
so i should just buy a kit instead of trying to piece this together cheaper ?
Also the drive shaft should be fine as i will only be at like 5'' suspension correct ?
I have 35'' mickey Thompson on it now, so im just gonna stick with those, what shocks would you guys recommend if they dont come in the package ?
And do the drop trac bar and pitman arm and transfercase ring come with the susp. package ?
Thanks
Edit:
Ive found these lift springs
http://cgi.ebay.com/ebaymotors/5-94-...Q5fAccessories
http://cgi.ebay.com/ebaymotors/7-94-...Q5fAccessories
I think the 5'' might be what i want now but ill always wonder what the 7'' would look like, what would you guys suggest for the rear ? Ill need another like 3'' back there, would a block be fine ? Also where can i get the trac bar bracket ?
Also will this drop pitman arm work fine ?
http://cgi.ebay.com/ebaymotors/Drop-...Q5fAccessories
Old Dec 8, 2009 | 05:35 PM
Twisted Metal's Avatar
Twisted Metal
Also the drive shaft should be fine as i will only be at like 5'' suspension correct ? Not 100% sure, but the driveshaft angle should not casue bind issues.
I have 35'' mickey Thompson on it now, so im just gonna stick with those, what shocks would you guys recommend if they dont come in the package ? Bilstiens Bilstiens Bilstiens they makea shock for 2-6" of lift, the number IIRC is 5100
Thanks
1- Yes Buy a Kit, comfirm before purchasing that it has the parts and pieces you need. Less headaches later on.
2-Not 100% sure, but the driveshaft angle should not cause bind issues.
3-Bilstiens Bilstiens Bilstiens they makea shock for 2-6" of lift, the number IIRC is 5100
4-See my first answer
Old Dec 8, 2009 | 06:03 PM
helms's Avatar
helms
Thanks
Edit:
remember that a 5" lift will only add 3" to your truck from stock height. your off-road package came with 2" of lift from the factory but the new lift kit will replace all the factory stuff. basically, when you do the tear town, you will be removing 2", then when you install the lift you will be adding 5", netting you 3".
You stated that you already have 2" coil spacers, added to your 2" factory lift so you already have a 4" lift... get it?
Old Dec 8, 2009 | 06:05 PM
helms's Avatar
helms
Its almost always better to buy a complete kit. unless you really know your stuff and find awsome deals on everything, piecing it together will just nickle and dime you to death.
Old Dec 8, 2009 | 06:21 PM
Augiedoggy's Avatar
Augiedoggy
I like when people lift there trucks cuz its funny to me. And silly. You really gain notheing. you can lift ur truck to the moon. But all in all you still have that thing called an axle in the way of hanging up. Now if you want clearance for off-roading lift it and do full independent suspension. Now thats the ticket. LOL IMO
well besides the added offroad capability better traction on and off road (more tire surface on the road) more complements and a look I like better on a pickup..(look at how many buy a pickup for the image alone and never even use the bed!)..yes frivolous things like the look sometimes matter to me and most others here and everyone has their own preference whether its stock, drop or lift. I also love the fact that I can work on the underside of my truck and do things like service the tranny and oil changes very easily without the use of a jack!.....undercoating the frame and rhinolining the rockers (which are higher up and less likely to rust if I ever park it on the grass or in mud which sometimes happens) is much easier as well....
and the last reason....I just find that people are that much more likely to get/stay the hell out of my way!
Old Dec 8, 2009 | 06:48 PM
nathangfnd's Avatar
nathangfnd
i thought the off road package basically came with a coil spacer, i may be wrong but isnt that what they do now?
Best way for lift is a kit, thats why they sell them. A good cheap kit with everything is from rough country, and it come with shocks.
They do not come with drop pitman arm or transfer case indexing ring unless you get the skyjacker 7 inch kit which comes with indexing ring.
Old Dec 8, 2009 | 06:53 PM
SpcD1500's Avatar
SpcD1500
Pittman arms are not that expensive neither are the indexing rings
http://www.summitracing.com/parts/SJA-DTSA10/
Old Dec 8, 2009 | 10:12 PM
chet's Avatar
chet
yea i understand this, thats why i was going with the 5'' springs to net me 3 more inches.
looks like ill price a rough country kit, whered you guys get yours ?
Old Dec 8, 2009 | 10:16 PM
chet's Avatar
chet
the off roads dont come with a coil spacer, the only thing up there is a little thin piece of rubber.
