Weird turn of events!
Old Dec 7, 2009 | 11:55 PM
sstgonzo's Avatar
sstgonzo
Default Weird turn of events!
Well I work at a dealership here my town and a few techs replaced a heater core on my Ram. Now it shifts around 3k when I am barely on the gas. Weird to me, would the ecu have anything to do with this? It was disconnected when we did the core removal. Anything would get me a start!
Old Dec 7, 2009 | 11:59 PM
moparama's Avatar
moparama
Did you check to see if the cable attached to the TB was knocked off?
Old Dec 8, 2009 | 12:03 AM
jasonw's Avatar
jasonw
Site Moderator
moparama has the right idea, I think.
To answer your question, no. The PCM/ECU in these Rams does not tell it when to shift 1 to 2 or 2 to 3 or vice versa. The only gear the PCM/ECU controls is the overdrive gear.
The TV cable, I think its called, is on the passenger side of the TB. It controls the shift points. Look it up in the 2001 service manual ("Merry Christmas" thread) or in a Haynes manual, both give a good procedure for adjusting it, IIRC.
Old Dec 8, 2009 | 12:17 AM
moparama's Avatar
moparama
+1 Thats what i was thinking of exactly.
sstgonzo's Avatar
sstgonzo
Ok thats a good start. Also I have to start in in neutral right now. It won't start in park.
Old Dec 8, 2009 | 12:18 AM
sstgonzo's Avatar
sstgonzo
But if it was knocked off it would'nt even throttle up at all.
Old Dec 8, 2009 | 12:22 AM
moparama's Avatar
moparama
sure it would its not the cable for the gas pedal. used to be called a kickdown cable.
Old Dec 8, 2009 | 01:09 AM
Ram_Me's Avatar
Ram_Me
On the passenger side of the TB, there are three cables hooked up. Start by making sure that they are all attatched correctly.
Old Dec 8, 2009 | 08:57 AM
audiomechanic's Avatar
audiomechanic
Sounds like the TV (Throttle Valve) cable is too tight Loosening it a couple of "clicks" will probably put it right where it needs to be.
Old Dec 8, 2009 | 06:06 PM
1fast2liter's Avatar
1fast2liter
to tight the truck thinks its in gear.....do the dashes have to be taken out all the way to replace the heater core? if soe make sure the lever to go into gear is adjusted right and yes i second the kick down cable check it make sure its attached and adjusted right
