Help/ Oil Pressure Question
Old Dec 8, 2009 | 07:57 PM
PilotMan's Avatar
PilotMan
Default Help/ Oil Pressure Question
Hey guy's, new guy here. I just bought yesterday a 1996 Dodge 3500 4X4 with a V-10 and auto trans. It only has 128,000 miles. It has a Mechanical oil pressure gauge hooked to the oil filter area. At idle I have 0 oil pressure at 70mph I have 25. A buddy of mine said I need to bleed the line as he thinks there is air in it? What do you pro's think. Thank you Steve
Old Dec 8, 2009 | 08:17 PM
PurplDodge's Avatar
PurplDodge
Whats the factory gauge say?
Old Dec 8, 2009 | 09:18 PM
95RAM360's Avatar
95RAM360
may be a clogged port
and if you hve 0 PSI at idle, its a bad idea to go up to 70 with only 25PSI IMO
any knocking?
Old Dec 8, 2009 | 09:26 PM
PilotMan's Avatar
PilotMan
No it runs and sounds great. The only guage is the mech one.
Old Dec 8, 2009 | 09:48 PM
95RAM360's Avatar
95RAM360
??? they should all come with an oil gauge on the cluster right? ive nevewr seen a ram without one.
Old Dec 8, 2009 | 09:54 PM
PilotMan's Avatar
PilotMan
Yes it did but they did away with it.
Old Dec 8, 2009 | 10:18 PM
PurplDodge's Avatar
PurplDodge
How??
Old Dec 8, 2009 | 10:43 PM
J415's Avatar
J415
I can only assume that the sensor either isn't there or is disconnected.
Old Dec 8, 2009 | 10:54 PM
Obiejuankinobie's Avatar
Obiejuankinobie
It was probably cheaper to hook up the mechanical one. I changed out my sensor. My old one gave me zero readings then climb when I gave it gas. The new sensor was astronomically high. We use to call them oil sendor switch. I guess by calling them sensors rather than switches you can charge a ton.
Old Dec 9, 2009 | 09:47 PM
PilotMan's Avatar
PilotMan
Default Up-Date on Oil Issue
Ok so today I decided to bleed the oil line. It did help some so now I have 0 at idle and at 1,200 rpm 20 psi and at 2,000 rpm 30 ish. If I quick rev it I get 60. So I guess for now it will be ok. Thanks every one who replyed. Steve
