Progress
Old Dec 9, 2009 | 01:42 PM
greenmachine's Avatar
greenmachine
Default Progress ---UPDATE!!!
Got most of the parts in for my baby. I have a new set of EQ Monster cylinder heads 2.02 / 1.62 stainless valves, 2bar map, sct, Pacesetter long tubes with which I will run 3 in dual exhaust, and a new pulley for the ProCharger that will give me 10lbs of boost(yeah). Once I am done I will post dyno info and video.
**UPDATE**
Heads on exhaust on started it up and it runs like poo!! No compression. Bent valve stems AARRGGHH!!! Nothing changed except for heads so off they come. Having them looked at now. I think they may have milled the heads or put in the wrong valve stems.
Old Dec 9, 2009 | 01:44 PM
dodgeram07's Avatar
dodgeram07
mmmmmmmmmmmm cam?
Old Dec 9, 2009 | 01:52 PM
RM_Indy's Avatar
RM_Indy
Look forward to seeing how you do!
Still 5.2L or did you stroke it as well? (cant remember)
Old Dec 10, 2009 | 11:03 AM
greenmachine
Forgot to mention the 1.72 Scorpion RR and hardened push rods so no cam. Still have the 5.2 all top end stuff right now. More later.
Old Dec 10, 2009 | 12:30 PM
dodgeram07's Avatar
dodgeram07
thats still sweet cause of the added lift,, i looked up scorpion and they looked to be alot cheaper,, do you have a link?? because the one i found were for Pontiac.
LT + 1.7rocker + heads= will sound sweet!!,,, take alot of pics
Old Dec 10, 2009 | 02:55 PM
greenmachine
The RR you want is the Ford 302 1.72 - 3/8 5/16 stud
Old Jan 20, 2010 | 09:37 PM
greenmachine
!!!bump!!!
Old Jan 20, 2010 | 10:00 PM
yakkier's Avatar
yakkier
Is it cold outside or is that whitesmoke ?
http://s228.photobucket.com/albums/e...t=100_1689.flv
Old Jan 21, 2010 | 12:59 AM
wake's Avatar
wake
holy **** man..i am defanitly getting long tubes after hearing that vid..
long tubes,no cat, flow master super 40 ...... DROOOOLLL!!!!
Old Jan 21, 2010 | 09:04 AM
greenmachine
Cold outside. The video I have posted is not the video with the exhaust upgrade. That video is from when I had the shorty headers and a single in / dual out 40 series flowmaster. All 2.5 inch.
