PO505 "Idle air control system malfunction"
Old Nov 2, 2025 | 04:40 PM
Dman2690's Avatar
Dman2690
@HeyYou I'm assuming ground negative lead to battery ground?
Old Nov 2, 2025 | 06:41 PM
That'll work.
Old Nov 3, 2025 | 10:33 AM
Dman2690's Avatar
Dman2690
I just checked and I only have 12 volt at one of four pins.
Old Nov 3, 2025 | 12:04 PM
Verify the wires are good. If they are, bad PCM. Pay attention to the connectors as well, sometimes they expand a bit, and don't make good contact.
Old Nov 3, 2025 | 03:46 PM
Dman2690's Avatar
Dman2690
Do you know what pins on the pcm connector the four wires are? Its been over six months since i messed with it last. And you want no resistance through the wire when ohmed, correct?
Old Nov 3, 2025 | 07:26 PM
Very little to no resistance. You can download the service manual for your truck from here. Wiring diagrams are in section 8W. There will also be a connector pinout section as well. Need to test all four wires.
