Dash lighting
Old Dec 10, 2009 | 11:51 PM
Miami_Son's Avatar
Miami_Son
Default Dash lighting
I don't drive much at night, so I never really noticed, but it appears that the panel with the headlight switch is completely dark even when the lights are on. The only thing that lights up there is the little indicator for the fog lamps. Is this correct? Shouldn't something light up just so you can find the switch easy at night?
Old Dec 10, 2009 | 11:55 PM
silverbullet-dodgeram's Avatar
i believe all the white symbols should light up when you turn the switch on
Old Dec 11, 2009 | 12:38 AM
dodge15004x45.9's Avatar
dodge15004x45.9
I think a new head light switch is in order. I know mine lights up. http://cgi.ebay.com/ebaymotors/98-99...ht_1366wt_1167
Old Dec 11, 2009 | 01:43 AM
2001Ram's Avatar
2001Ram
Dont order a brand new switch, take the black bezel cover off ( very carefully, you know about dodge plastic) There are 3 screws that holds the switch in place, 1 on top, 2 on bottom. Pull the entire thing out, there is a bulb in there that you can replace. DONE. lol
Old Dec 11, 2009 | 02:53 AM
Laramie1997's Avatar
Laramie1997
^1+ Had a friend do this and I just happened to show up the day he talked about putting his new switch in. You'll really want to pull the switch and check it first since the turn style switches aren't cheap. Last time I priced one, it was right at $50.00 with my discounts. (which is a killer on some things and not even worth using on others)
We pulled that switch out and it was just the little bulb. So, in the end, a $50.00 fix turned into a $.50 fix.
Old Dec 11, 2009 | 09:22 AM
EndIsNear's Avatar
EndIsNear
Yep, thats what I did with my LED mod. Just a little twist screw with a bulb in the end.
Old Dec 11, 2009 | 10:50 AM
lord0fsal3m's Avatar
lord0fsal3m
before you go to crazy check and make sure your dimmer is all the way up, stupid mistake ive done it a lot and thought i blew a fuse or something
Old Dec 12, 2009 | 02:48 AM
dakotas ram's Avatar
dakotas ram
the key switch should light up also, correct?
Old Dec 12, 2009 | 07:12 AM
95RAM360's Avatar
95RAM360
yes the key switch lights up
as for the headlight switch, i have the same problem Miami, and found tha the thick solid blue wire had no power, which i believe is the wire that illuminates. i havent fixed it for its been out since i bought it, and ive gotten use to it
Old Dec 12, 2009 | 10:14 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
To the best of my knowledge, my headlight switch has never lit up.
