Cleaning Intake manifold
Old Dec 14, 2009 | 12:28 PM
J415's Avatar
J415
Originally Posted by 95RAM360
^ that wasnt the only flaw with the plenum and wont perminatly fix it
I would like someone to prove INDEFINITELY, that the plenum plate is the main problem.
Old Dec 14, 2009 | 02:02 PM
aim4squirrels's Avatar
aim4squirrels
I cannot prove DEFINITIVELY that the plenum plate is the problem. No one can really, as a recall or TSB was never issued to fix the true problem.
There are 3 prevailing theories as to why the plenum blows. It could be one, two, or a combo of all three reasons as to the true reason:
1. When Chrysler designed the Intake, they failed to countersink the bolt holes deep enough for the bolts used to secure the plate and gasket, resulting in a seal at the incorrect torque to properly hold a seal.
2. Poor quality OEM paper gasket.
3. The plate and intake manifold was made of different material which expanded and contracted at different rates, resulting in a gradual tearing of the gasket.
I suspect it's probably a combo of all 3, to varying degrees. The Hughes and APS plates address all three issues: thick aluminum plate with a felpro gasket.
Old Dec 14, 2009 | 02:58 PM
95RAM360's Avatar
95RAM360
thats the other reason combined with the long bolts
