Cleaning Intake manifold
Old Dec 13, 2009 | 07:12 PM
Cant Dodge It RAM IT's Avatar
Default Cleaning Intake manifold
I am planning on taking the intake manifold off and cleaning. what is the best way of doing this and since i got it apart is there anything else i should be doing at that time with 125k? 5.2l
Old Dec 13, 2009 | 09:01 PM
95RAM360's Avatar
95RAM360
https://dodgeforum.com/forum/members...er-mod-yet.jpg
went to the machine shop and it cost me 40 bucks to make mine look like this.
GET A HUGHES OR APS PLENUM PLATE so you dont have to worry about the plenum gasket again (this allows oil to leak into manifold when blown)
this gave me better gas milage with those (13-14 city, and about 17-18 highway in my 5.9L with 196K no joke)
and my oil PSI is at like 55-60
Old Dec 13, 2009 | 09:12 PM
my truck is eating oil right now i was planning on replacing the rings if the compression is low but ill be doing that soon. thanks ill keep it posted
Old Dec 13, 2009 | 09:14 PM
95RAM360's Avatar
95RAM360
Plenum will eat oil, and every second gen ram will have a problem with the plenum. it was a poor design on Dodges part. They've done a "Deathflash" to re-tune the computer to cope with the leaking plenum instead of actually fixing it....if your truck ha had this done i think you need to get it reprogrammed
by the way the Plenum is the plate bolted to the bottom of the manifold if you didnt know.
Old Dec 13, 2009 | 09:18 PM
what does the plenum plate do? and is there a diff between the brands?
Old Dec 13, 2009 | 09:23 PM
95RAM360's Avatar
95RAM360
the plenum does nothing...you can actually get manifolds that are sealed on the bottom. (Hughes airgap intake)
http://hughesengines.com
dont just get a new plenum plate, get the Hughes reienforcment Plenum. It basically eliminates it and you dont have to worry about it again.
i have the Hughes Plate, and i love it...and since my manifold is clean inside...and i have the Plate, it runs so good, you can feel it has way moe airflow, and runs 100x better
Old Dec 13, 2009 | 09:33 PM
i have a 1994 ram 1500 5.2 l and i dont see one there to get can u please show a link
Old Dec 13, 2009 | 10:59 PM
dhvaughan's Avatar
dhvaughan
here you go.
this is the plate and gasket.
http://www.hughesengines.com/Index/p...d&partid=22220
this is the intake bolt and gasket kit.
http://www.hughesengines.com/Index/p...b&partid=23039
Old Dec 14, 2009 | 10:11 AM
greenmachine's Avatar
greenmachine
or just get you shorter bolts and a new gasket =-)
Old Dec 14, 2009 | 12:20 PM
95RAM360's Avatar
95RAM360
^ that wasnt the only flaw with the plenum and wont perminatly fix it
